Old 04-01-2015, 11:25 PM   #1
HachiRo
Drives: 2013 White-Out FRS
High RPM for current speed
First, I'm not sure where to post this, but it's sortve related to the engine so yeah..
This is my first 4 cylinder car and also my first ManTran, so I'm not sure if it's normal or something's up with my car. Is it normal for the car to be around 3k RPM when driving 70mph?
On my older Accord and 5-series (98 and 97), 70mph was closer to 2.5k RPM.
HachiRo is offline   Reply With Quote
Old 04-01-2015, 11:27 PM   #2
navanodd
Drives: 2013 BRZ Sport-tech WRB
Yeah, that sounds correct. My auto reads 2k at 60mph and the manual is geared a bit more aggressively.
navanodd is offline   Reply With Quote
Old 04-01-2015, 11:28 PM   #3
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Yes, its normal.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 04-01-2015, 11:28 PM   #4
Tank
Mumbler
Tank's Avatar
Drives: Sensibly
Yes, that's normal.
Tank is offline   Reply With Quote
Old 04-01-2015, 11:43 PM   #5
Teseo
Drives: frs
Yup, 70mph at 3000 rpm in 6th gear
Old 04-02-2015, 04:49 AM   #6
HachiRo
Awesome! Thank you everyone :P Definitely some stress off my mind.
Old 04-02-2015, 06:44 AM   #7
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
its not normal ... its just the way our car is set up though .. normally most cars are not that high RPM when on the highway
for the twins it is normal for the manual transmissions, auto is a bit lower (i haven't actually checked but from the gear ratio im guessing it is)
Old 04-02-2015, 07:06 AM   #8
ajc209
Drives: GT86 Cosworth
formula one cars idle at 6k rpms....
This is a high revving engine (compared to most road cars with ~6k rpm red line) so gear ratios are ajdusted accordingly to take advange of those rev's and put down a bit more torque....
3Krpm is only 40% of total revs. 2400rpm is 40% of 6K.....
ajc209 is offline   Reply With Quote
Old 04-02-2015, 08:40 AM   #9
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
4:10 gear ratios on the manual is the reason your RPM is higher.
Auto is a 3:83 I think??? Reason why it gets a little better highway gas mileage, but the manual is faster.
2016 Camaro SS is offline   Reply With Quote
Old 04-02-2015, 09:24 AM   #10
Koa
Jesus...
Old 04-02-2015, 09:35 AM   #11
Originally Posted by Koa View Post
Jesus...
Old 04-02-2015, 11:43 AM   #12
MAPerformance
Drives: Asphalt FRS
Perfectly normal. Try my S2k with 4.77 gears. 5k at 70mph
MAPerformance is offline   Reply With Quote
Old 04-02-2015, 01:46 PM   #13
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I sit at around 800rpms at 70mph
When coasting
Old 04-02-2015, 01:58 PM   #14
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
The rear diff ratio is the same for auto and manual.... 4:10. The 6th gear ratio in the transmission is lower with the autos than manuals.
Digitalanalog is offline   Reply With Quote
Hood flutter at high speed TheseColorsDontRun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-10-2013 10:39 AM
Scion FR-S completely ruined during a high-speed chase vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 2 07-05-2013 12:09 PM
Brakes unless at high speed - what to tackle? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 10-12-2012 05:06 PM
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 12:37 AM
Casey Stoner high speed cornering at 1000fps tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 6 08-01-2011 04:20 PM
