Old 07-14-2016, 07:38 AM   #1
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Stability Control intervention at very low speed
At low speed, without traction control off, going around a corner at about 5 mph, the stability control will lose it's shit and start throwing out rear brake for no reason, with the stability sontrol light flashing like crazy. Then, the stability control light and ABS light will stay illuminated.
On track, as long as I do the pedal dance, there is no noticeable issue, however the ABS / TC light will stay illuminated every once in a while, with no change in drivability. If the ABS / stability control light come on first, I cannot get traction control off or do the pedal dance.
Any ideas where to start?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 07-14-2016, 07:48 AM   #2
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
What mods do you have installed? First thing that comes to mind is wheel speed sensor.
Old 07-14-2016, 08:16 AM   #3
smbstyle
smbstyle's Avatar
car is lightly track prepped (RCE T2's, AP brakes, header, cat delete, OFT tune, misc. safety equipmt, slicks)
2013 SWP BRZ
Old 07-14-2016, 02:00 PM   #4
humfrz
I'd start by disconnecting the battery for a spell ....... then re-connect ....... to see if the system would right itself.
humfrz
Old 07-14-2016, 02:30 PM   #5
guybo
Huge E85 fan!
guybo's Avatar
Is your wheel setup staggered or square?
Old 07-14-2016, 05:25 PM   #6
Mr Nerd
Mr Nerd's Avatar
Do you use the Torque app?
Mr Nerd is offline   Reply With Quote
Old 07-15-2016, 08:06 AM   #7
smbstyle
smbstyle's Avatar
square setup
2013 SWP BRZ
Old 07-15-2016, 08:06 AM   #8
smbstyle
smbstyle's Avatar
I have it, but haven't used it on this car.
2013 SWP BRZ
Old 07-15-2016, 08:07 AM   #9
smbstyle
smbstyle's Avatar
humfrz
thanks. Yep, did that. still have the issue.
2013 SWP BRZ
Old 07-15-2016, 12:10 PM   #10
kch
Senior Misanthrope
kch's Avatar
With Doug's incident and the newly blown diff, it could be anything. Have y'all replaced the diff already? Could be related to that.
Old 07-15-2016, 02:11 PM   #11
strat61caster
strat61caster's Avatar
Toe?
ineedyourdiddly
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Vehicle Stability Control twostroke BRZ First-Gen (2012+) — General Topics 15 07-13-2014 11:10 AM
Stability Control? ashtray BRZ First-Gen (2012+) — General Topics 27 01-24-2013 05:32 PM
TPMS, LSD and Stability Control FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 11-05-2012 04:12 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
