Old 03-04-2012, 12:45 PM   #1
alluringreality
Drives: Subaru
Light weight and high winds in a Subaru
I bought a 2012 Impreza a couple months ago to replace a 1997 v6 Camaro. Driving 70-75 MPH with crosswinds over 25 MPH and gusts around 40 MPH my Impreza gets pushed around in high Kansas winds. A good gust can move the car across the road about a foot, and with stronger straight-line winds it was necessary to noticeably steer in and out of the wind at underpasses by turning the wheel up to maybe three inches. The dealer seems to think it's to be expected given the weather conditions, but except for farm or moving trucks I haven't driven anything that requires as much correction in high interstate winds as the Subaru.
Any opinions on how the BRZ may handle in high winds? The BRZ surely has a smaller profile than the 4th generation Camaro, but it's also at least 500 pounds lighter. I would guess the Camaro probably has the most weight per side area of the cars mentioned. On the other hand the BRZ has a lower center of gravity, and it's not all wheel drive like the Impreza. Based on weight probably the answer to this question is to buy a Dodge, or according to http://www.thetruthaboutcars.com/201...t-wheel-drive/ I should buy front wheel drive, but most likely I would be cross-shopping either the base 2013 Genesis Coupe or maybe the v6 Mustang. Compared to those two cars, do you think the BRZ's light weight will prove worse for interstate travel?
alluringreality is offline   Reply With Quote
Old 03-04-2012, 12:57 PM   #2
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
I also live in KS and we have a '12 Impreza Sport. I have been driving in windy weather like you on the interstate at +70mph and have not had any issues whatsoever. Been steady just like our previous car. I'm surprised you are having issues. Driving I-70 or I-35?
Regarding the BRZ, it will sit lower, has a smaller profile and lower cd than most cars. I don't think you will have a problem.
tranzformer is offline   Reply With Quote
Old 03-04-2012, 12:57 PM   #3
Double4Free
Ashes to ashes.
Double4Free's Avatar
Drives: Asphalt FR-S
I'm guessing it'll be flying all over the roads if going at high speeds with gusts of wind. My current winter DD comes in just over 2400 pounds, and it flys all over the place. 300 more pounds should help stabilize it a bit more, but i'm guessing that its gonna have similar problems with the wind at high speeds.
Double4Free is offline   Reply With Quote
Old 03-04-2012, 01:22 PM   #4
tranzformer
Drives: Zoom Zoom
I think with the BRZ sitting lower it will help. But obviously we won't know until we try it. Not like you will be driving in conditions like this on a daily basis. I'm sure you will survive the few to several times it happens every year. With a strong side gust of wind, you probably shouldn't be driving 75-80mph anyways.
What is your DD?
Old 03-04-2012, 01:32 PM   #5
Double4Free
Ashes to ashes.
During summer/spring/fall usual DD is a 2012 3.5 Altima Coupe. During winter time i switch on over to my first car, 2000 Toyota Corolla.
Old 03-04-2012, 01:38 PM   #6
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
the low center of gravity helps reduce weight transfer from one side to the other and reduces the effect of roll-over and handling feedback. also the brz has a small side projected surface area reducing the effect of being pushed around by high winds. but i wouldn't worry too much about high winds but i guess we won't know 'til the car is released.
azian_advanced is offline   Reply With Quote
Old 03-04-2012, 01:41 PM   #7
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
cross winds are typically nasty to vehicles with a larger flatter surface area. Obviously larger cars, trucks, SUVs, and Trailers will feel the effect of cross winds the most regardless of weight.
The shape of the Zx6 is very slippery for a road car against forward facing winds with a .27 coefficient of drag. But when we talk about side facing winds at 25mph, against the Zx6 traveling at a 60mph hwy. We start to worry about stability.
But in my opinion, with the Zx6, i don't believe a small, low to the ground, low center of gravity sports car will experience the pushing effects of crosswinds and road instability like other similar vehicles at similar speeds.
WingsofWar is offline   Reply With Quote
Old 03-04-2012, 01:48 PM   #8
tranzformer
Drives: Zoom Zoom
I don't know for sure, but I would guess a 2000 Corolla sits ~ 6-8in higher than a BRZ? Part of the issue is that a Corolla is about as aerodynamic as a brick compared to the BRZ and doesn't sit as low. The BRZ should be quite a bit more stable than your Corolla I am guessing without having driven the BRZ yet.
Old 03-04-2012, 01:51 PM   #9
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
I don't think getting blown around by the wind will be an issue, but if you're looking for a highway cruiser the BRZ is probably not the best choice. The light weight means it will get tossed around by bumps in the road and the gears, at least in the mt, aren't geared for low highway RPMs. I think the GC or mustang would be a better choice if you are looking for a highway cruiser.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 03-04-2012, 01:56 PM   #10
tranzformer
Drives: Zoom Zoom
Sure. I would argue that neither a GC/Mustang are great highway cruisers either. If you want a highway car get a Kia Optima turbo or a Sonata turbo or something similar. Will be more comfortable and be more efficient at highway speeds.
Old 03-04-2012, 02:25 PM   #11
fatoni
No it doesnt
Old 03-04-2012, 02:37 PM   #12
alluringreality
Drives: Subaru
My gripes have been driving I-70. The worst straight-line winds I've driven in was:
http://www.wunderground.com/history/...atename=Kansas
The gusts last Saturday afternoon were not unusually high for Kansas, and still it was enough to push the Impreza 6" or more at interstate speeds:
Old 03-04-2012, 02:44 PM   #13
Xlr8
Drives: 2013 Ultramarine FR-S
Would you say the G37 Coupe is a good highway car or am I just stuck with Optima or Sonata. Have you seen the new 2013 Fushion? Do you think it would be a good highway car?
Also do you think the nose on a BRZ will be pushed around more than the FR-S in an +80MPH crosswind? I mean that front bumper looks like a big wind sail.
Xlr8 is offline   Reply With Quote
Old 03-04-2012, 02:45 PM   #14
YaX
Seρor Member
YaX's Avatar
Drives: 2005 Holden Monaro aka Pontiac GTO
Move?
When purchasing a car, I have to consider whether the AC is strong enough to overcome the Texas heat, but if I have to figure out how a car does in a hurricane during my daily commute, I'm LEAVING that state.
YaX is offline   Reply With Quote
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 03:48 PM
High praise in Popular Mechanics' Subaru BRZ review Sport-Tech BRZ First-Gen (2012+) — General Topics 16 12-11-2011 12:35 PM
Subaru BRZ High Resolution Wallpapers in World Rally Blue and Matte White FT-MH BRZ Photos, Videos, Wallpapers, Gallery Forum 30 12-02-2011 10:26 PM
Subaru FT86 still not have the green light! ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2011 04:57 AM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
