Old 03-21-2017, 01:32 AM   #1
Allen86
Drives: Silver BRZ
What do you use for tranny and diff
What oil should I use for my AT to change the transmission fluid and differential fluid?
Also I have FI
Allen86 is offline   Reply With Quote
Old 03-21-2017, 11:00 AM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
You'll get lots of differing opinions, and probably a few "do a search" comments. If it were my car, I would go with Redline D6 trans fluid for the auto, and Redline 75W85 or 75W90 GL5 gear oil for the differential.
Old 03-21-2017, 02:49 PM   #3
wrh3
billswebspace.com
wrh3's Avatar
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
I used Ford XT M5 QS Synthetic Transmission Fluid for the transmission and Amsoil Severe Gear 75w110 for the differential.
The Ford Synthetic transmission fluid is GL4 and the Miata guys rave about it, I had some left over from the Miata days. Much better shifting than OE.
Bill
BillsWebSpace.com
wrh3 is offline   Reply With Quote
Old 03-21-2017, 05:23 PM   #4
swarb
Do a search
Motul
Old 03-23-2017, 02:26 PM   #5
Allen86
Drives: Silver BRZ
What is the difference between the 75W85 and the 75W90?
Old 03-23-2017, 02:29 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-24-2017, 07:56 AM   #7
roddy
roddy's Avatar
The 75W85 is the recommended fluid, with 75W90 as an acceptable alternative (by the manual). 75W85 is a bit thinner than 75W90. Either one will be fine. You're in Texas, so I would probably go with the 90. If you plan on tracking the car in the heat, it probably wouldn't hurt to step up to the 75W110 as @wrh3 has done.
Old 05-15-2017, 05:04 AM   #8
Allen86
Drives: Silver BRZ
Just recently installed the oil you recommended me and it is awesome! I don't feel the clunky shifting from 2nd to 3rd gear pull anymore. That OEM shit sucked!
Old 05-16-2017, 04:51 AM   #9
ristar
Anyone have any experience with valvoline maxlife atf in these? I'm looking at it for cost reasons, the car doesn't and won't see the track, and from what I can tell it's a better option than the toyota ws. The motul multi-af is in my price range as well, but for the price difference i can get an extra drain and fill out of the valvoline. Thoughts?
ristar is offline   Reply With Quote
Old 05-16-2017, 10:34 AM   #10
dattran86
Driver
Drives: 2013 Whiteout FRS
Motul gear 300 is GL4/5.
U can buy 4 bottle and replace both transmission and diff.
dattran86 is offline   Reply With Quote
Old 05-16-2017, 11:30 AM   #11
ristar
Not in an automatic I can't. Well I guess I could, but that'd probably go poorly.
Old 05-16-2017, 01:58 PM   #12
Originally Posted by 8RZ View Post
5.
....... SA.......
Old 05-16-2017, 05:43 PM   #13
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
....... SA.......
A true SA would have said:
"Personally I do not use any tranny, but what you do behind closed doors is your own business!"
nextcar is offline   Reply With Quote
Old 05-16-2017, 08:28 PM   #14
roddy
roddy's Avatar
Thanks for the disturbing mental image of getting "tranny fluid" all over the place...
Part Numbers for Tranny & Diff Washer BRZY Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 03-24-2025 11:51 AM
MotulGear 75W90 okay for tranny and diff? midnitz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 07-18-2016 09:44 AM
Does BRZ come stock w/ magnetic drain plugs (diff/tranny)? Daedex Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-05-2014 08:50 PM
Should I change my diff oil and tranny oil Anthony7515 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 02-24-2014 11:30 AM
