Old 02-22-2014, 04:37 PM   #1
Anthony7515
brz owner
Drives: 2013 Subaru brz white
Should I change my diff oil and tranny oil
I heard all the factory fill for the diff oil tranny oil and engine are all garbage should I change the diff fluid and tranny fluid or just leave it and just change my engine oil?
Anthony7515 is offline   Reply With Quote
Old 02-22-2014, 05:29 PM   #2
humfrz
Well, Anthony7515, my opinion is that if the transmission and differential oils should be changed sooner than the maintenance schedule states ..... the manufacturer would have changed the schedule.
However, with severe use, such as heavy track use, it may be wise to change them sooner.
Others, I'm sure, feel differently .....
humfrz
Old 02-22-2014, 06:39 PM   #3
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
I'm going to change mine before I pull it out of storage in the spring. I've seen some pretty nasty looking pictures of cars with gunked up magnetic plugs... Ultimately you probably don't have to, but it wouldn't hurt. There is someone running a package deal thing that comes with 4 bottles of Motul Gear 300, and the necessary crush washers. It has everything you need for both the trans and the diff.
http://www.ft86club.com/forums/showthread.php?t=17759
FReSh is offline   Reply With Quote
Old 02-22-2014, 11:31 PM   #4
Anthony7515
brz owner
My car only has 6400 miles
Old 02-23-2014, 12:50 AM   #5
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
IMO I would drive it on factory trans and diff for 10K than Change it out to get rid if assembly gunk including any tiny metal fragments as the gears and such wear in, after that I would not touch it again. The engine there are tons of opinions on that and tbh it's up to you what you want to do - i.e follow the manual to a 'T' or do better and change it earlier for the first one and then follow the manual...that's my two cents.
Gords_zenith is offline   Reply With Quote
Old 02-23-2014, 12:21 PM   #6
executivekoala
executivekoala's Avatar
Drives: fr-s
I would do the diff, when I did mine it was black and had more than normal shavings. Trans oil seemed fine and had minimal shavings. I noticed the transmission and diff engage better when shifting that about it. To me...worth it. I'm at 20k miles btw
executivekoala is offline   Reply With Quote
Old 02-23-2014, 02:32 PM   #7
Anthony7515
brz owner
Yeah I think I'm gunna change all the oils then leave it alone because this was my first manual car so I prob am better off doing that then just doing an oil change from then on
Old 02-23-2014, 04:05 PM   #8
CSG David
CSG David's Avatar
Well to be fair, garbage in what context? What driving application are you seeking?
Old 02-24-2014, 11:17 AM   #9
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
See this thread
There is an overwhelming amount of people that seem to agree that you should change your fluid for various reasons and that is what has got me worried about my fluid. I didn't read through that entire thread so I didn't see if there was a professional opinion posted without seeming like they were just trying to sell something. If you guys know something I don't please share...
@CSG David
EvilBeaverFace is offline   Reply With Quote
Old 02-24-2014, 11:30 AM   #10
CSG David
CSG David's Avatar
Originally Posted by EvilBeaverFace View Post
See this thread
@CSG David
If you don't drive your car extremely spiritedly, just follow your owner's manual's severe use section (for that higher change interval rate). There is a break-in period for your engine, tranny, and differential and thus requires you to change the fluid periodically. The change interval is more important than the fluid alone. The fluid you use in the tranny/diff should be directly related to the application you seek to use your car for. While metallic dust seems to be a concern, it'll clear up with proper change interval. If you see chunks...well...you have a bigger problem that no fluid can ever fix.
On a side note, this car prides itself over smooth shifts.
Part Numbers for Tranny & Diff Washer BRZY Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 03-24-2025 11:51 AM
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
manual tranny bjun BRZ First-Gen (2012+) — General Topics 19 01-29-2013 05:57 PM
tranny fluid change Dispect Engine, Exhaust, Transmission 3 01-27-2013 11:31 AM
MT vs AT tranny... better MPG, 0-60? subatoy BRZ First-Gen (2012+) — General Topics 163 03-26-2012 06:08 PM
