Old 03-01-2017, 05:01 PM   #1
FT86.ca
Drives: '15 BRZ, '05 Acura TL
Why isn't there a 2nd drain plug on the bottom of AT oil pan?
Hi All,
I've been trying to trying to figure out why didn't Subaru/Toyota add a 2nd drain plug at the very bottom of the automatic transmission oil pan so it's easier to replace ALL (or what's in the pan) the oil at once. I know there's a torque converter somewhere that hold more fuild but that's besides the point.
Having to drain/fill 3 times seems like a lot of waste as you are draining of the new oil on the 2nd and 3rd drain/fill.
I've searched high and low for this answer and my thinking is that it could only be the following.
1. Keeping costs lower
2. Subaru/Toyota thinks we are stupid and we might screw up the fluid change somehow.
3. Something might go wrong if the transmission fluid goes below the level of the overflow plug during the fluid change.
I was going to insert a thin tube through the refill plug or overflow hole and suck up as much of the old fluid as possible to get the most old stuff out. I'd thought I'd ask you guys before something goes wrong.
Vic
FT86.ca is offline   Reply With Quote
Old 03-02-2017, 02:44 AM   #2
I'd bet on your 2nd point.
Old 03-02-2017, 11:41 AM   #3
4. The engineers that designed the car were not worried about the little bit of oil left in the pan during a change.
Dadhawk (03-02-2017), JazzleSAURUS (03-03-2017), KalbiCool88 (04-05-2017), radroach (03-04-2017)
Old 03-02-2017, 11:53 AM   #4
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Considering the amount of old fluid that gets left in the converter and the rest of the transmission during a typical pan drain/filter change, the few ounces left behind are of no consequence.
Old 03-02-2017, 11:59 AM   #5
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Originally Posted by FT86.ca View Post
Hi All,
Vic
Do you happen to have a part # for the drain and refill plug gaskets?
xsnapshot is offline   Reply With Quote
Old 03-02-2017, 12:14 PM   #6
http://www.ft86club.com/forums/showthread.php?t=15654
Old 03-02-2017, 05:37 PM   #7
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
5) Stupid engineers think you would rather just dent the pan when you scrape bottom on your low car instead of ripping out the drain plug.
nextcar is offline   Reply With Quote
Old 03-02-2017, 05:44 PM   #8
xsnapshot
Fast enough
Same for AT as MT?
Old 03-02-2017, 06:58 PM   #9
Stark Performance
Drives: 2014 FR-S
There is, in fact, a drain plug.
As for the drain and refill procedure, I hear you, it is onerous and wasteful. Just make sure that you cycle the fluid like the service manual says. That way, the fluid goes through the valve body and torque converter.
Stark Performance is offline   Reply With Quote
The Following User Says Thank You to Stark Performance For This Useful Post:
Tcoat (03-02-2017)
Old 03-02-2017, 07:54 PM   #10
Same for AT as MT?
Yep. Also the diff.
Old 03-04-2017, 07:35 PM   #11
radroach
Drives: car
That wee bit of grit left down there is beneficial for the lifetime (or at least until necessary replacement or rebuild) of the transmission.
Old 03-04-2017, 09:40 PM   #12
Meh. Compared to all the grit stuck in other spots that would be a pittance. Just don't let the car sit for several hours before changing it and it should all be stirred up anyway. If it doesn't stir up and just sits there we are back to it being a none issue.
radroach (03-05-2017)
Greddy Oil Drain Plug - Leaking Pokeguyjai Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 09-25-2016 05:16 PM
Drain plug leaking...what to do... OUGrad05 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-28-2016 03:01 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Best magnetic drain plug? FR-Sizzle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-28-2015 02:07 PM
Oil Drain Plug Size jjkerr626 Engine, Exhaust, Transmission 3 11-28-2014 07:20 PM
