Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
08-25-2012, 06:12 PM | #1 | |
Drives: World Rally Blue BRZ
Part Numbers for Tranny & Diff Washer
Looking to drain my transmission and differential fluids out and fill them up with Amsoil. I tried calling Oakland Subaru/Toyota (same dealer) for these parts. The tranny & diff washers are special order since they do not stock them (yet?). As I understand from vast experience with Honda parts, special order parts are nonrefundable. Searching the forum, I found these part numbers:
Just in case anyone is wondering about the oil filter: Oil filter: 15208-AA-130 (old style, better?) http://www.ft86club.com/forums/showthread.php?t=12392 |
The Following User Says Thank You to BRZY For This Useful Post: | Sportsguy83 (11-28-2012) |
08-25-2012, 06:18 PM | #2 |
if anyone have links to online sellers, please share.
08-25-2012, 09:56 PM | #3 |
Drives: '89 911, '06 GTI, '13 BRZ
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV |
09-21-2012, 06:31 PM | #4 |
Drives: FR-S, Exige S, Miata
I just went to both Subaru and Toyota dealer for these washers/gaskets. The Subbie dealer doesn't have any in stock and has to order them because he said the tranny is made by Toyota (Isn't it an Aisin AZ6?). He told me the tranny washers are over $8 each so I said no thanks and went to the Toyota dealer. Toyota tells me its over $11 each . Anyway, these are the parts number I got from them:
Differential fill plug gasket: SU00300122 @$2.30 each Differential drain plug gasket: TOY1215710010 @$1.50 each Transmission fill/drain plug gasket: SU00303626 @>$11 each I'm assuming the new "SU" parts number means they are Subaru parts? I only got the drain plug gasket for the differential since that is the only one they have now. I believe its because it has the old parts number and they used it for other vehicles also. I'm not going to sweat the fill plug gasket for the diff. I'm just going to flip the old one and reuse it. The fill plug is near the top and the differential is not under any pressure so I'm sure it'll be fine.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '95 Miata (Montego Blue) |
09-25-2012, 03:51 PM | #5 |
Drives: 1995 Acura Integra GS-R
Just got a both pairs with part numbers quoted from Opie at Subaru. Rear diff drain and fill plugs look identical, but are both crush type washers. I recommend getting new ones to form a better seal. Price is 1.73 for fill, 1.98 for drain.
Yes, the transmission fill/drain washers are freaking $7.87 each. These are solid washers, and do not seem like they require replacing, but I special ordered these so I bought them. Though I got them at net price it was still freaking $5.19/washer. |
The Following User Says Thank You to xn7485 For This Useful Post: | ft86Fan (09-25-2012) |
03-26-2015, 02:20 PM | #6 |
Drives: 2013 Whiteout FR-S
Could there be another part # for SU00300122 ? I can't seem to find it in certain parts catalogs.
08-27-2015, 04:06 PM | #7 |
Sleep Chomper
Copper gaskets from O'Reilly's can be substituted for transmission gaskets they say. OIL-TITE! PN# 65275 11/16", M18
08-27-2015, 04:58 PM | #8 |
Turning is for Nerds
Drives: 35 characters is not enough
Anneal, flip, and reinstall.
The Following User Says Thank You to Decay107 For This Useful Post: | Grady (05-12-2023) |
08-28-2015, 10:12 PM | #9 |
Drives: 2013 BRZ 6MT
I just changed my trans and diff fluids today. I got the necessary washers at:
www.belmetric.com |
The Following User Says Thank You to PWBRZ For This Useful Post: | steezypenguin (08-28-2015) |
09-10-2015, 09:41 PM | #10 | |
Drives: 2015 Brz Blue Series
Part # references on belmetric website? Last edited by Donbrz; 09-11-2015 at 12:00 AM. Reason: Clarify |
09-11-2015, 01:32 AM | #11 |
Transmission
2 flat washers - 24mm OD x 18mm ID x 2mm (drain and fill are same size) Belmetric: GA18X24T Differential 2 crush washers - 24mm OD x 18mm ID x 2mm (drain and fill are same size) Belmetric: GCA18X24 The stock washers I took off the transmission were virtually identical to the Belmetric GA18X24T. The stock washers from the differential were similar to Belmetric GCA18X24 but not copper. To be honest, if you wanted to you could even use the same ones used for the transmission. Just make sure to use a torque wrench to get proper torque to 'crush' the washers. |
The Following 5 Users Say Thank You to PWBRZ For This Useful Post: | Donbrz (09-11-2015), jflogerzi (02-11-2021), Lakitu (06-19-2018), nomtimesthree (03-23-2024), robotleader (03-15-2022) |
09-11-2015, 11:00 AM | #12 | |
05-12-2023, 07:19 AM | #13 |
Drives: gt86
Thanks for the info, have you had any leaks yet? And it works like the original version?
Similar Threads | ||||
Badge / Wheel cap Part numbers | lordtakuban | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-09-2012 04:43 PM |
Part numbers | 20valvewynn83 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-24-2012 06:16 AM |
How do I get JDM part numbers? | InstantNoodles | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-09-2012 04:29 PM |
Subaru part numbers for stock brake rotors? | blalor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 06-28-2012 02:31 PM |
part numbers | Staticfrost | BRZ First-Gen (2012+) -- General Topics | 5 | 05-29-2012 12:02 PM |
