#15 |
Drives: 2013 Firestorm FR-S
OK it was a blown EFI CTRL fuse. Replaced with one of the spares and she started right up. When I originally did the intake install I stupidly left the battery connected. Assume that blew it? Would love for someone to chime in and educate me on why this migt have happened. I am an electrical noob.
And thank you everyone for the help!
| The Following 3 Users Say Thank You to ajh88 For This Useful Post: |
#16 |
Did you remove any ground wires that didn't get reinstalled?
| The Following User Says Thank You to FirestormFRS For This Useful Post: | Overdrive (01-29-2017) |
#17 | |
Drives: FT86
Arrh ok i think the key start models should crank and even start if key code not read but will cutout after about 5 seconds with no code , not ,100% on this though. check fueses anything to do with ecu or ignition like they other guy said of you have a device to read edu error codes that may help |
#18 | |
Drives: FT86
#19 |
when I installed my Grimmspeed CAI, I didn't unplug my battery. I had no blown fuses and the car started right up. not sure why your fuse blew but it shouldn't be normal. I never unplug my battery because I'm lazy and don't want to reset my radio channels lol
#20 | |
Drives: FT86
Checked the wiring diagrams the EFI CTRL fuse feeds power to a whole lot of sensors (VVT , port injectors ,vvt position sensors, CPC solenoid) including the MAF sensor. Id sat somehow the maf sensor cable red wire B+ pin got shorted to earth at some point |
| The Following User Says Thank You to steve99 For This Useful Post: | Sportsguy83 (01-30-2017) |
#21 |
Huge E85 fan!
Drives: 2016 Scion FRS
For something simple like an intake I never disconnect my battery either (same reason- I don't want to have to pair my phone and reset radio stations) but I do pull the ECU fuse to reset the fuel trims.
That's really weird. How the hell did it blow that fuse once you got the car started? How do you like the intake so far? |
#22 | |
Panda Trueno
Drives: No twin now.
This. It is an intake. |
#23 | ||
Huge E85 fan!
#24 |
The Blitz Advance intake has a small plate sandwiched between the intake and the MAF, and since the instructions were in japanese I inadvertently put two of the screw sleeves on the wrong side of the sandwich. This positioned prevented the MAF sensor from going all the way down into the chamber, by maybe a centimeter (however long the screw sleeves are). But it was enough to upset the MAF reading to make the engine shut off.
This is my daily so once I got everything running again I held off on the install. Will revisit this weekend. Got a SARD quad exhaust and TRD bumper garnish to put on too - arrived today - if I'm feeling ambitious. But it's cold...
| Advanced Keys Push to Start Install in progress For the FRS. | milkesfrs | Cosmetic Modification (Interior/Exterior/Lighting) | 117 | 04-25-2020 03:17 AM |
| DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) | Chaetagnath | DIY (Do-It-Yourself) Guides | 225 | 09-03-2017 05:20 PM |
| HELP! After Unichip install, car won't start!!! | husker741 | Issues | Warranty | Recalls / TSB | 21 | 01-10-2015 10:50 PM |
| Shop to install Viper alarm/start? | l0aded | Southern California | 0 | 05-04-2014 06:57 PM |
| Schematic for remote start install? | empower-auto | Electronics | Audio | NAV | Infotainment | 3 | 07-31-2012 05:13 PM |
