Old 07-03-2013, 08:33 PM   #1
husker741
HELP! After Unichip install, car won't start!!!
Uhhhh wtf do I do?
husker741 is offline   Reply With Quote
Old 07-03-2013, 08:49 PM   #2
Philly758
Drives: GMC
Make sure all the plugs are inserted all the way, check ground, check maps... Worst case take it off? This isn't a warranty/recall issue, this has nothing to do with subaru/scion.
Philly758 is offline   Reply With Quote
Old 07-03-2013, 09:12 PM   #3
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Agreed. Plus unhook the battery to reset the ECU after checking all connections that you may have disturbed during the install. Did you put the MAF back in facing the right way?
Like he said, if all else fails take it back off and try it stock.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 07-03-2013, 09:14 PM   #4
husker741
Went back to stock and now have a CEL
Old 07-03-2013, 09:32 PM   #5
ScionFrsFan
Make sure you have the intake hose fully connected...mine was loose and cause cel. Mine got loose after playing around with unichip. If car isn't starting the 3rd plug...ah I forgot what one that is called (behind engine) If that one is not fully connected I know the car wont start.
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 07-03-2013, 09:42 PM   #6
Lonewolf
Lonewolf's Avatar
Drives: Moped
This sounds a lot like something was left unplugged or installed improperly (throttlebody issue or crank angle sensor disturbed)...recheck all your connections..
Did the car attempt to crank at all..or was it just silent, sitting there doing nothing?
What is the CEL code? That could help us help you as well...
Old 07-03-2013, 09:50 PM   #7
Asphalt~86
Drives: Asphalt AT
Sounds like you forgot the grounding wire.
Asphalt~86 is offline   Reply With Quote
Old 07-03-2013, 11:05 PM   #8
husker741
Cruise control will not turn on. Does that mean a specific code? I don't have a code reader. The car started to crank but would not turn over.
Old 07-03-2013, 11:52 PM   #9
topazsparrow
Drives: slow
why in the world are you installing unichip on your car if you don't even have a code reader???
topazsparrow is offline   Reply With Quote
Old 07-04-2013, 01:21 AM   #10
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
what did unichip say when you contacted them to troubleshoot your installation?
shiumai is offline   Reply With Quote
Old 07-04-2013, 01:36 AM   #11
husker741
Since when is it required? I have the Flux2, but I hadn't installed it so I couldn't read the code. A lot of people have this without a code reader.
Old 07-04-2013, 01:36 AM   #12
husker741
Got no answer.
The Following User Says Thank You to husker741 For This Useful Post:
shiumai (07-04-2013)
Old 07-04-2013, 01:36 AM   #13
husker741
Well now the CEL went off. I'm not sure what's going on, but I'll try the installation again soon.
Old 07-08-2013, 05:43 PM   #14
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
To me it sounds like you forgot to install something. The instructions aren't the best honestly. When I forgot to install the 1/0 switch to the large pin connector (I connected to the small connector) my car would not start. When I finally got it to start I had a CEL which was cleared after a battery reset. I don't know how Flux works since I don't have one but make sure it is plugged in the right spot.
l0aded is offline   Reply With Quote
DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) Chaetagnath DIY (Do-It-Yourself) Guides 225 09-03-2017 05:20 PM
Best Unichip Map for Me? husker741 Software Tuning 11 07-31-2013 08:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Schematic for remote start install? empower-auto Electronics | Audio | NAV | Infotainment 3 07-31-2012 05:13 PM
