Old 11-27-2013, 04:27 PM   #1
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Advanced Keys Push to Start Install in progress For the FRS.
Hey Guys / Gals
I just wanted to show an Advanced Keys / Push to Start install in progress on a M/T FRS. The M/T FRS has a M/T neutral wire that you can hook up to so the remote start is good to go. Let me start out by saying I have found a new respect for the people who do installs for a living. I have done a lot of Mother F-ing but the systems features have been coming online one by one. I will do a full write up so the next ones that do this install can to it in a short amount of time. The system is pretty slick.
Bad thing is you need 2 Idatalink bypasses modules for the lock / unlock and transponder bypass. I paid 110.00 2 bypasses and 40.00 for the USB adapter to flash the module.
So far I got the following to work as intended . No key needed just the smart Fob in your pocket
Push to Start ( good )
Door lock / Unlock as you walk or walk away from the vehicle ( Good )
Arm & Disarm as you walk or walk away from the vehicle ( Good )
Remote start is a work in progress. Advanced Keys Support has been A+++
Pic # 4 is a Kenwood KOS-A300 Media controller add on that is discontinued. You can pickup for 35.00 on Ebay. It works great and for 35.00 you cant beat it. Makes the dash look high tech and it works great. I seen the same set up in my bro's BMW.
milkesfrs is offline   Reply With Quote
The Following 7 Users Say Thank You to milkesfrs For This Useful Post:
Grip Ronin (01-19-2014), Guff (01-13-2014), kmbkk (12-01-2013), luv85 (11-28-2013), M-17 (12-10-2013), OjiGeorge (12-14-2013), YamahaR86 (12-12-2013)
Old 11-27-2013, 08:55 PM   #2
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Major props for doing this the right way and achieving results.
Acree is offline   Reply With Quote
The Following User Says Thank You to Acree For This Useful Post:
milkesfrs (11-27-2013)
Old 11-28-2013, 09:46 AM   #3
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
@milkesfrs where did you buy the fr-s specific kit?
WTB: FA20 longblock in Socal or shipped.
FTEIGHTSIX is offline   Reply With Quote
Old 11-28-2013, 09:50 AM   #4
DIM
Great write up so far! Looking forward to seeing it finished.
And I saw this kit on Amazon.
DIM is offline   Reply With Quote
Old 11-28-2013, 09:52 AM   #5
FTEIGHTSIX
FTEIGHTSIX's Avatar
Can someone link me? I only found the easy go push to start on amazon.
Old 11-28-2013, 01:44 PM   #6
DIM
Oops, sorry I mixed those 2 haha.
Old 11-28-2013, 07:26 PM   #7
luv85
Drives: Grey GT
So you need 1 Idatalink bypasses modules for the lock
and 1 more Idatalink bypass for unlock?
luv85 is offline   Reply With Quote
Old 11-30-2013, 09:30 PM   #8
milkesfrs
milkesfrs's Avatar
Drives: hot lava
This kit is not specific to the FRS. Its a universal kit. I got the kit online from a company called Advanced Keys. I like this kit better than the Easy-Go because you don't have to change out the door handle, you get remote start and it cost less.
I went to the Subaru dealer and ordered the plastic pocket to mount the push to start button for 11 dollars.
Old 11-30-2013, 09:34 PM   #9
milkesfrs
milkesfrs's Avatar
Drives: hot lava
You need one Idatalink bypass module for lock/unlock and the other bypass is for your immobilizer to be able to start your car with out the key in the lock cylinder. Its sucks but there is no way around not getting 2 .
Old 11-30-2013, 10:17 PM   #10
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Here are a few tips if you install this unit in your M/T FRS.
1. Make sure to hook up the neutral safety wire and test that it is working. Don't just ground it out or you will see you car rolling down the street without you in it if you forget and leave it in gear when you remote start !
2. Run a tach wire from the engine bay into the car to hook up to the units tach wire. The push to start will be one touch instead of holding the button down until the car starts.
3. Run a fused wire from the battery to power your unit. DO NOT TAP INTO THE EMPTY SPOTS ON YOUR FUSE BOX. You need a 30 amp fuse. If you do tap into the fuse box and blow a fuse you could damage your unit and maybe you car. I know because I did this on my Acura and it cost me 2000.00 to have all the wiring harness replaced. Not good.
4. All the wires you need to tap into are on the side of the driver side dash and kick panel. The hardest wire to find was the security light for the IMO bypass. I found the purple wire behind the fuse box right above the clutch pedal. It was tight trying to get back there.
Old 12-01-2013, 12:39 AM   #11
ir1064
Drives: 6MT, C7P
how long it takes for this DIY? really interested to do it next spring, thanks!
ir1064 is offline   Reply With Quote
Old 12-01-2013, 02:55 AM   #12
milkesfrs
milkesfrs's Avatar
Drives: hot lava
I took my time and it took about 7 hrs from start to finish.
The Following User Says Thank You to milkesfrs For This Useful Post:
Twitchy313 (03-26-2019)
Old 12-01-2013, 09:29 AM   #13
ir1064
Drives: 6MT, C7P
sounds great, this totally can be a weekend project when spring time comes, thanks!!!!
The Following User Says Thank You to ir1064 For This Useful Post:
Old 12-01-2013, 05:53 PM   #14
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Would it be possible to do a Viper style (operated from a smartphone) style with our cars?
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) Chaetagnath DIY (Do-It-Yourself) Guides 225 09-03-2017 05:20 PM
Advanced Keys for GT owners..? luv85 Australia Classifieds 10 10-22-2013 06:48 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Advanced Keys Inc + Viper 5904 Iddoit2er Electronics | Audio | NAV | Infotainment 5 02-24-2013 02:50 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
