Old 01-07-2017, 08:32 PM   #15
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by azynneo View Post
checked all the lines, also brought it to toyota as well to check, couldn't find a leak but they could definitely unburnt fuel. The leak only happens on cold starts and right after I fill up my tank.
You mentioned an aftermarket fuel pump; how is it installed?
I'd start looking there; something like it spews fuel out a breather if the tank level is too high, or something - I'm guessing without knowing much about the fueling setup in the car, let alone what you have.
Old 01-07-2017, 08:40 PM   #16
azynneo
csg installed the pump, already gave David a holler waiting for a response
azynneo is offline   Reply With Quote
Old 01-07-2017, 08:42 PM   #17
all fine, I just turned my car on without starting it and noticed a huge ass leak like a liter of fuel dripping out of my car as I moved it down the hill.
Fuel pump runs when you turn on the ignition. I believe it only shuts off after ecu detects target fuel pressure on the low pressure rail. If you have a leak [maybe] the pump just keeps going. The access panel is glued on underneath the left rear seat.
Or maybe it's a slow leak. A liter?
edit: Clarified intent to suggest possibility, not to state as fact. What the hell do I know?
Old 01-07-2017, 09:31 PM   #18
Originally Posted by Teseo View Post
My dad used to find gas leak while smoking, talk about safety
Huffing gas while smoking cigarettes ....... ahhhh, the good old days ......
humfrz is online now   Reply With Quote
Teseo (01-07-2017)
Old 01-07-2017, 10:06 PM   #19
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
check the hoses around the evap cannister. It could be the rollover valve too. I'm betting that when the new fueling system was put in they missed a hose or the rollover valve was stuck open.
Crazy question- when you fuel up, does the fuel fill click off (when the tank is full) like it did before the new fuel pump was installed?
guybo is offline   Reply With Quote
Old 01-08-2017, 02:01 AM   #20
azynneo
Yeah it clicks
Old 01-11-2017, 10:52 PM   #21
azynneo
update now happens every morning upon startup leaves puddle of fuel. Tried contacting csg but too slow to respond. Brought it to a Toyota dealership and they can't find a problem. Anyone know the cost to fix a gasket for the fuel tank? if that is the case.
Old 01-12-2017, 02:45 PM   #22
JoeC
Drives: Subaru BRZ Limited
every morning and you're still driving it, huh? after a month? we're talking about gasoline right? like you're car's leaking gas and you're still driving it every day? I can't possibly be understanding this correctly.
JoeC is offline   Reply With Quote
Old 01-12-2017, 04:29 PM   #23
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
What's your point?
Scrappydoo is offline   Reply With Quote
Old 01-12-2017, 04:34 PM   #24
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
Only thing I can suggest is to have someone raise the car up and get the leak to occur, then just trace it to it's exact location and diagnose from there. From everything you've said I want to say it's the tank itself but it's mainly covered by protection pans, which means that if it really is the tank then it's a much worse leak than it looks like because the unburned fuel is pooling inside the pan and slowly leaking through. That could explain why you're always smelling unburned fuel in the back. That still wouldn't explain why the leaking only occurs at specific times and isn't constant, though.
Perhaps the tank is leaking constantly. Is your fuel gauge dropping suddenly between every drive? Is there always a pool of fuel when you start up and move? Or is it only when you start up in the morning and fill up the tank like you said?
Silver Cervy is offline   Reply With Quote
Old 01-12-2017, 04:36 PM   #25
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
He has had it checked by a Toyota dealer
Old 01-12-2017, 04:41 PM   #26
Silver Cervy
He never said that they looked at the tank, though. If the leak only happens at the specific times he mentioned then Toyota wouldn't have seen it. The fact that he hasn't mentioned the exact spot where the fuel is leaking means that neither he nor Toyota have found it yet.
Old 01-12-2017, 04:44 PM   #27
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
He never said that they didn't look at the tank either.
Old 01-12-2017, 05:05 PM   #28
azynneo
I only get a leak during start up and before it warms up small drops of gas til it's completely warmed.
Smells like leaking gas in the car.. babykwiss Issues | Warranty | Recalls / TSB 16 07-08-2015 03:30 PM
Two of the best smells in the world... NWFRS Off-Topic Lounge [WARNING: NO POLITICS] 24 04-02-2015 07:56 PM
My oil smells like fuel HRTROB Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 07-17-2014 09:02 AM
A/C smells after fuel pump replacement G.I.Choe Issues | Warranty | Recalls / TSB 5 12-18-2013 11:25 AM
Oil smells like fuel SloS13 Issues | Warranty | Recalls / TSB 21 03-10-2013 10:56 PM
