Old 12-26-2016, 04:38 PM   #1
azynneo
Smells like unburnt fuel
So today I let the car go past E, filled the car up and now I've been smelling unburnt fuel for 20 miles and hasn't gone away yet.
I have an aftermarket fuelpump and injectors, didn't smell any fuel from the engine bay but smelling fuel near the rear. Anyone's guess?
azynneo is offline   Reply With Quote
Old 12-26-2016, 04:44 PM   #2
stevesnj
stevesnj's Avatar
make sure the gas cap is on, if it is turn it counter clockwise a hair until you feel the cap lid loosen not the cap itself. Or remove the cap slowly to remove any pressure. Check all around the fuel system for drips.
My 2016 Build thread
Old 12-26-2016, 05:19 PM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
It could be an issue with your evap system. Is the CEL on? Have you checked codes?
Old 12-26-2016, 05:46 PM   #4
azynneo
CEL's not on
Old 12-26-2016, 06:06 PM   #5
humfrz
Oh, maybe it was soo thirsty, that when you filled it, some gas spilt over the filler tube and that's what you're smelling.
I wouldn't worry about it unless the smell persists or you get a light...
humfrz
Old 12-26-2016, 06:34 PM   #6
azynneo
humfrz
<_< I feel like I'm being trolled here
The Following User Says Thank You to azynneo For This Useful Post:
PandaSPUR (01-07-2017)
Old 12-26-2016, 06:46 PM   #7
humfrz
I'm sorry you feel that way. That's not my intent ...... sometimes, I just joke around a bit ......
Please let me explain, if you overfilled the tank, either by forcing fill past the click off on the nozzle or the pump just malfunctions and doesn't shut off ...... some fuel can slip past the filler tube into the fender well area. Gasoline trapped in there can take a while to evaporate and can smell for some time, especially in colder weather.
PS - I don't troll people ...... sometimes I pull their leg or yank their chain .... but do not troll .....
humfrz
jcw99 (01-12-2017), Ultramaroon (01-07-2017)
Old 12-26-2016, 06:59 PM   #8
azynneo
humfrz
Ah, gotcha. I'll update you to see if the smell goes away I got a diffuser stuck down there so kinda hard to check if fuel is leaking around the pump.
Old 01-07-2017, 12:47 PM   #9
azynneo
smell the fuel again, this time I see fuel leaking rear driver side
a little information about the car, I do have an aftermarket fuel pump and injectors.
Old 01-07-2017, 12:58 PM   #10
Teseo
Drives: frs
Check fuel lines, injectors connection and fuel pump while engine running
Old 01-07-2017, 01:38 PM   #11
azynneo
all fine, I just turned my car on without starting it and noticed a huge ass leak like a liter of fuel dripping out of my car as I moved it down the hill.
Old 01-07-2017, 01:56 PM   #12
cjd
cjd's Avatar
Drives: 2017 BRZ
Somehow I'm convinced that all is NOT fine... find that leak! And be very careful.
Old 01-07-2017, 02:02 PM   #13
Teseo
Drives: frs
My dad used to find gas leak while smoking, talk about safety
Old 01-07-2017, 08:19 PM   #14
azynneo
checked all the lines, also brought it to toyota as well to check, couldn't find a leak but they could definitely unburnt fuel. The leak only happens on cold starts and right after I fill up my tank.
Smells like leaking gas in the car.. babykwiss Issues | Warranty | Recalls / TSB 16 07-08-2015 03:30 PM
Two of the best smells in the world... NWFRS Off-Topic Lounge [WARNING: NO POLITICS] 24 04-02-2015 07:56 PM
My oil smells like fuel HRTROB Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 07-17-2014 09:02 AM
A/C smells after fuel pump replacement G.I.Choe Issues | Warranty | Recalls / TSB 5 12-18-2013 11:25 AM
Oil smells like fuel SloS13 Issues | Warranty | Recalls / TSB 21 03-10-2013 10:56 PM
