BOXER FR
Drives: WRB BRZ Limited
sti control arm on brz?
so, I plan on installing the PERRIN PSRS kit, but do not want to try and press out the bushings on my OEM control arm as I may revert the car back to stock, etc... One idea i had was to purchase a used STI control arm, which if i remember correctly is the same design as our arm, just installed reverse. I remember from my NASIOC days the weight saving from the stamped piece (which is on our cars) to the aluminum piece was not much, but the aluminum arm is much stiffer.
has anyone done this before? photo of STI GR arm for reference: FRZ arm:
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
#2 |
Drives: 2014 Subaru BRZ
We haven't installed STI front control arms in the BRZ before, so we're not sure how they'll fit, they might be compatible. Has anyone else tried it? That would be a nice upgrade!
#3 |
BOXER FR
looks like i might be the guinea pig trying it...
#4 |
Drives: 2005 Toyota Camry
What year STi?
#5 |
Drives: Subaru BRZ, Toyota MR2 Turbo
I'm also not sure if the arm would physically bolt on to the FR-S/BRZ mounting points. I do know that the ball joint from the STi is NOT compatible with the FR-S/BRZ.
#6 |
Drives: 2013 Firestorm FRS
sub'd
#7 |
Drives: 10 Series #974 6m/t
#8 |
BOXER FR
i think any GR would work? I dunno for sure but I`ve heard that the BRZ arm is just a WRX (GR) arm installed rotated.
#9 |
BOXER FR
turninconcept confirmed it would NOT fit..
#10 |
Drives: Fr-s
I know this is old, but was it clarified as to why? Is it a non starter or something that could be easily(relatively) overcome.
#11 | |
BOXER FR
#12 |
Drives: Legacy GT
Ball joints are different, that would be the main issue assuming the inner mounts line up. On the other subarus the ball joint sits in the upright, not the control arm. So there is a smaller conical seat that would not be compatible with the brz upright and ball joint.
And then spacing between the inner mounts is probably not the same anyway, and who knows what it would do to caster if they did actually line up. Probably would place the wheel too far back in the wheel well. Cusco also makes arms that look pretty cool. Last edited by jamal; 12-29-2016 at 02:28 PM. |
#13 |
Because compromise ®
Drives: Red Herring
The SPL version looks pretty hot.
#14 |
Drives: Subaru BRZ Limited M/T
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 01:48 PM |
| Traction Control vs. Stabilization Control vs. Sport Question | MurderRider | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-07-2014 12:56 PM |
| WTB: Front Lower Control Arm and Rear Upper Control Arm | YDNA | Brakes, Suspension, Chassis | 0 | 11-10-2013 04:40 AM |
| ok this traction control is... out of control | dori. | BRZ First-Gen (2012+) — General Topics | 13 | 01-31-2013 06:05 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 11:20 AM |
