Drives: 2015 Raven FR-S 6MT
Traction Control vs. Stabilization Control vs. Sport Question
After crawling and searching for threads that clearly explain the pros and cons of these three settings that can be toggled on and off, even in combination with each other, I have yet to get a clear pro/con list for each. I would only like the pro con list here to be for the manual version of the car, as that is what I have. So here are the 3 things I need clarity on.
What are the pros and cons of having VSC Sport mode on or off? Pros and cons of having Traction Control on or off? And then, finally, when I hold the Traction Control button down, I get what I think is Traction Control off and Stabilization off (the SPORT does not light up in this mode). What is the pros and cons of this (hold it down) mode? Please mention if any of these settings increase acceleration speed on a manual car going in a straight line. Thanks. |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
[ame="https://www.youtube.com/watch?v=j8qggahGNH0"]Toyota 86 Traction Control Demonstration [SKIDPAD] - YouTube[/ame] As you can see from the video. Pressing VSC sport allows a bit more slip angle over normal. If you press the traction control button briefly -- TRAC OFF appears. It's mainly for getting out of snow / mud, where you don't want the traction control to interfere. Traction control turns back on after you exceed 31mph. If you press and hold the traction control button, then majority of the systems are off (outside of doing the pedal dance). None of these settings affect throttle response on MT as far as I'm aware. |
didn't you read your owner's manual?
step 1: start your FRS step 2: hold down both buttons for 15 seconds step 3: drive |
Drives: 2013 DGM BRZ
Exactly what dhuang said.
With all off you can get off the line much quicker due to getting closer to the edge of traction. Personally I've automated the "press and hold the traction control button" procedure so I'm always in this both off mode whenever I drive. |
Drives: '14 BRZ Limited
#6 | |
#7 | ||
Drives: Whiteout Scion FR-S
To shut off all of the annoying nannies for track use, warm up the car and then do the pedal dance. Without the pedal dance, the rear brakes still intervene in some corners – the car is much faster and more predictable (and more fun!) on the track without the nannies if you know what you are doing: http://www.ft86club.com/forums/showt...ht=Pedal+dance You could also try the pedal dance for straight-line acceleration. It may or may not improve things. I do have a manual transmission and did do the pedal dance at an autocross once. I was able to get a good wheel spinning launch off the line in this mode.
#9 | |
#10 |
Drives: car
I found that I was able to achieve much smoother driving during AutoX with Sport Mode ON but with TC ON. When I turned it off, I couldn't rely on the brake vectoring any more to steer me through corners, instead would peel out through many of them, slide, or even spin if I gave it too much throttle. In sport mode you can hammer the throttle and the TC will slow you down some, brake on the inside wheels for you. Though it feels much more natural to drive with the TC off, especially when starting in 1st (allows for that extra bit of slip), I prefer having TC on when doing tricky cornering, the brake vectoring helps a lot.
#11 |
Reverse Burnouts
Drives: 2013 Argento FRS
10% wheel slip delivers the best acceleration
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#12 | |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
#13 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
You don't want traction control on if you are trying to launch...unless you want it to cut power on you.
[ame="https://www.youtube.com/watch?v=jFuApgwCVrg"]2014 Scion FR-S 0-60 MPH Acceleration Test Video - 6-Speed Manual Transmission - YouTube[/ame] I always drive with traction/stability control 'off'... the systems are nothing but a hindrance and handicap to the chassis for me, and the absolute last thing I want the car to do is unnecessarily cut power on me and brake when I need to turn quickly and accelerate. And anything less than 'off' is absolutely horrible on track. I forgot to turn the system off once and when on track I quickly hit the button to put it in VSC Sport mode because I didn't feel like going back into the hot pits... that session SUCKED! ABS and EBD going crazy and engine cutting power in tight quick turns...YUCK!
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#14 |
Drives: 2013 Scion FRS
With stock tires and suspension, I don't think you will have many times that the system will engage the brakes due to rear tire lift.
VSC On => Pros: More slip angle before the system kicks in Quicker lap times in general Slightly bigger grin when driving hard over normal mode Cons: Harder on tires and gas(Caused by larger grin )Mistakes will cost more time due to the system having to reel it in more Chances of losing control are higher Traction Control => Pros: Better launches Unless not enough revs, it won't bog down In inclement weather, can help keep momentum Cons: Harder on tires Maybe not as consistent Too much spin in snow and your getting the shovel It deactivates itself after you hit a certain speed Full off => Pros: Clarkson level smile Drifting Best lap times Fun in the comfort of the speed limits Did I mention HUGE SMILE on your face when pushing the car? Cons: Very hard on tires and gas If you have no skills, could end up in a wall or wraped around a pole Mistakes can be VERY costly in time and possibly money(See above) Sudden lost of traction due to weather can cause lost of control I did an autocross with the button push and had a blast. There is also and on ramp that I like to slow down to 20-30 km/h in 2nd and just kick the rear out. Very easy in dry, but be very careful in wet. I spun out once trying it . I also tried in vsc mode and it really kicks in hard if you're over aggressive. On the track, it's probably much more gradual.Depending how much experience you have, be very careful in off mode. Everyone has different skill levels, and I don't know you or anyone else on this forum nor have I seen anyone drive. Find an autocross race or an empty parking lot that would be ok with you having fun. You don't want to be having fun then having the cops show up and handing you a ticket. Do it in a safe environment. The on-ramp I have fun has great visibility, no signs, curbs or walls that can be hit, tight enough that not a lot of speed is carried and shallow ditch, so the risk is very low to cause damage to my car. I also do not do it when I see cars ahead or behind me. |
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 02:48 PM |
| Traction Control Question | Canehda | Issues | Warranty | Recalls / TSB | 30 | 10-22-2013 08:19 PM |
| Sport mode/traction control | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-05-2013 05:54 PM |
| traction control question | Sileighty_guru | BRZ First-Gen (2012+) — General Topics | 9 | 09-26-2012 10:54 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 12:20 PM |
