Old 01-31-2013, 04:57 PM   #1
dori.
Seρor Member
dori.'s Avatar
Drives: white BRZ 6MT
ok this traction control is... out of control
I've noticed it before in small amounts when it was wet before.
The traction control gets really aggressive in the wet.
Last night it was raining like crazy, and I was hooning around with all the 'nannies' OFF (both traction/slip light) and I was still getting the TC and ABS kicking in (and flashing wildly on the dash). What gives?
I heard of some pedal dance technique you can use to totally disable it, but do I have to do it every time I get into the car?
dori. is offline   Reply With Quote
Old 01-31-2013, 05:00 PM   #2
Squishy
Drives: 2013 WRB BRZ
Pedal dance to disable nannies and yes this must be done everytime the car is started.
http://www.ft86club.com/forums/showt...sable+traction
Here is the thread where they talk more about when the EBD and traction light kicks in only during more aggressive braking scenarios.
If this is not happening during only aggressive braking then you should verify you have fully disabled the VSC and traction and not just pushing the buttons to light up the two icons.
Here is a thread with a mod to disable the nannies with a timed relay to do the pedal dance basically at start up - but I think this is still not going to work until the condition of engine warm up is met but saves the inconvenience of the motions.
Squishy is offline   Reply With Quote
Old 01-31-2013, 05:02 PM   #3
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
mines off for maximum fun
GT86drifter is offline   Reply With Quote
Old 01-31-2013, 05:02 PM   #4
Calin
VTEC just kicked in, yo!
Calin's Avatar
Drives: World Rally Blue BRZ - 6MT
Yup, unfortunately the pedal dance resets itself every time you turn the car off. I don't think there's any way to permanently disable it.
Calin is offline   Reply With Quote
Old 01-31-2013, 05:10 PM   #5
rhoyle
Drives: BRZ SWP 6MT
The traction control doesn't know that it's wet.
rhoyle is offline   Reply With Quote
Old 01-31-2013, 05:11 PM   #6
dsgerbc
Drives: BRZ(sold), STI
'Pedal dance' is fine on the track. I'm not sure I'd want my EBD disabled on the street.
dsgerbc is offline   Reply With Quote
Old 01-31-2013, 05:15 PM   #7
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Removing the steering wheel turns everything off for good. Replace it with a race wheel and you won't have anything.
post_break is offline   Reply With Quote
Old 01-31-2013, 05:22 PM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Or just unplug the clockspring.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
CSG Mike (01-31-2013)
Old 01-31-2013, 05:27 PM   #9
wheelhaus
wheelhaus's Avatar
the "pedal dance" is to enter a diagnostic mode for troubleshooting, IIRC.
If nannies are turned off via the buttons, you've actually turned off only TC and VSC, which 99% of the time is what we're after. ABS and EBD are still left on (which is a very good thing in the vast majority of cases). You may still get the TC light flashing if you go Mr Dorifto, but it's only flashing to alert you of the condition.
Even for hooning or track days, you should not need the ABS and EBD disabled unless you really, REALLY need to, such as combinations of certain conditions/scenarios/setups on the track where driving at the limit can be disrupted by such devices' interaction.
wheelhaus is offline   Reply With Quote
Old 01-31-2013, 05:31 PM   #10
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
The only time EBD really becomes an issues is when trail breaking into a corner. It tends to not like what's going on and wigs out a bit. @CSG Mike can speak to that.
Other than that, I've seen all kinds of videos where people are sliding these cars around like mad men with no problems. If the nannies weren't going off all the way (aside from EBD and ABS) this wouldn't really be possible, even in the wet.
Nathan
SubieNate is offline   Reply With Quote
Old 01-31-2013, 05:38 PM   #11
dsgerbc
Yes, with some high-mu track pads. I'm sure electronics in our cars aren't calibrated for those. IIRC on stock pads in the rear, it's a non-issue.
Old 01-31-2013, 05:47 PM   #12
post_break
post_break's Avatar
Do tell!
The Following User Says Thank You to post_break For This Useful Post:
cobrabyte (01-31-2013)
Old 01-31-2013, 06:00 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Do tell!
Clockspring = steering angle sensor = TCS is broken. I'm not sure if it'll disable EBD but that's the same thing an aftermarket wheel without the clockspring is doing.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-31-2013, 06:05 PM   #14
I like to get some more rotation out of the car mid-corner by touching the brake sometimes... can't do it without the pedal dance
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
CEL/Traction Control Lights artizhay Issues | Warranty | Recalls / TSB 5 11-04-2012 10:33 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
TPMS and Traction Control Mavrik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-02-2012 01:50 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
