Old 11-12-2015, 02:42 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
sti control arm on brz?
so, I plan on installing the PERRIN PSRS kit, but do not want to try and press out the bushings on my OEM control arm as I may revert the car back to stock, etc... One idea i had was to purchase a used STI control arm, which if i remember correctly is the same design as our arm, just installed reverse. I remember from my NASIOC days the weight saving from the stamped piece (which is on our cars) to the aluminum piece was not much, but the aluminum arm is much stiffer.
has anyone done this before?
photo of STI GR arm for reference:
FRZ arm:
mokinbird87 is offline   Reply With Quote
Old 11-13-2015, 11:52 AM   #2
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
We haven't installed STI front control arms in the BRZ before, so we're not sure how they'll fit, they might be compatible. Has anyone else tried it? That would be a nice upgrade!
PERRIN_Chris is offline   Reply With Quote
Old 11-13-2015, 12:18 PM   #3
mokinbird87
BOXER FR
looks like i might be the guinea pig trying it...
Old 11-13-2015, 12:48 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
What year STi?
Old 11-13-2015, 03:39 PM   #5
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
I'm also not sure if the arm would physically bolt on to the FR-S/BRZ mounting points. I do know that the ball joint from the STi is NOT compatible with the FR-S/BRZ.
Jeff@Racer X Fab is offline   Reply With Quote
Old 11-13-2015, 03:52 PM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sub'd
Old 11-13-2015, 03:54 PM   #7
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
so basically its a no go for OP
Old 11-13-2015, 03:58 PM   #8
mokinbird87
BOXER FR
Originally Posted by mav1178 View Post
What year STi?
i think any GR would work? I dunno for sure but I`ve heard that the BRZ arm is just a WRX (GR) arm installed rotated.
Old 11-16-2015, 11:24 AM   #9
mokinbird87
BOXER FR
turninconcept confirmed it would NOT fit..
Old 12-25-2016, 10:21 AM   #10
redlined600
redlined600's Avatar
Drives: Fr-s
I know this is old, but was it clarified as to why? Is it a non starter or something that could be easily(relatively) overcome.
redlined600 is offline   Reply With Quote
Old 12-28-2016, 03:25 PM   #11
mokinbird87
BOXER FR
they didnt really elaborate.. and now that SPL front control arm has released no need for anything else
Old 12-28-2016, 05:36 PM   #12
jamal
jamal's Avatar
Drives: Legacy GT
Ball joints are different, that would be the main issue assuming the inner mounts line up. On the other subarus the ball joint sits in the upright, not the control arm. So there is a smaller conical seat that would not be compatible with the brz upright and ball joint.
And then spacing between the inner mounts is probably not the same anyway, and who knows what it would do to caster if they did actually line up. Probably would place the wheel too far back in the wheel well.
Cusco also makes arms that look pretty cool.
jamal is offline   Reply With Quote
Old 12-29-2016, 12:15 AM   #13
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The SPL version looks pretty hot.
Old 12-29-2016, 12:32 AM   #14
FastWhite
Drives: Subaru BRZ Limited M/T
Try here!!
http://racerxfabrication.com/
FastWhite is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 12:56 PM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 04:40 AM
ok this traction control is... out of control dori. BRZ First-Gen (2012+) — General Topics 13 01-31-2013 06:05 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
