-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   sti control arm on brz? (https://www.ft86club.com/forums/showthread.php?t=97557)
mokinbird87 11-12-2015 02:42 PM
so, I plan on installing the PERRIN PSRS kit, but do not want to try and press out the bushings on my OEM control arm as I may revert the car back to stock, etc... One idea i had was to purchase a used STI control arm, which if i remember correctly is the same design as our arm, just installed reverse. I remember from my NASIOC days the weight saving from the stamped piece (which is on our cars) to the aluminum piece was not much, but the aluminum arm is much stiffer.
has anyone done this before?
photo of STI GR arm for reference:
http://www.iwsti.com/forums/attachme...3&d=1328676779
FRZ arm:
http://photos.motoiq.com/MotoIQ/Tech.../IMG2517-L.jpg
PERRIN_Chris 11-13-2015 11:52 AM
We haven't installed STI front control arms in the BRZ before, so we're not sure how they'll fit, they might be compatible. Has anyone else tried it? That would be a nice upgrade!
mokinbird87 11-13-2015 12:18 PM
looks like i might be the guinea pig trying it...
mav1178 11-13-2015 12:48 PM
What year STi?
Jeff@Racer X Fab 11-13-2015 03:39 PM
I'm also not sure if the arm would physically bolt on to the FR-S/BRZ mounting points. I do know that the ball joint from the STi is NOT compatible with the FR-S/BRZ.
continuecrushing 11-13-2015 03:52 PM
sub'd
NyC Zn6 11-13-2015 03:54 PM
so basically its a no go for OP
mokinbird87 11-13-2015 03:58 PM
Originally Posted by mav1178 (Post 2450496)
What year STi?
i think any GR would work? I dunno for sure but I`ve heard that the BRZ arm is just a WRX (GR) arm installed rotated.
mokinbird87 11-16-2015 11:24 AM
turninconcept confirmed it would NOT fit..
redlined600 12-25-2016 10:21 AM
I know this is old, but was it clarified as to why? Is it a non starter or something that could be easily(relatively) overcome.
mokinbird87 12-28-2016 03:25 PM
they didnt really elaborate.. and now that SPL front control arm has released no need for anything else :)
jamal 12-28-2016 05:36 PM
Ball joints are different, that would be the main issue assuming the inner mounts line up. On the other subarus the ball joint sits in the upright, not the control arm. So there is a smaller conical seat that would not be compatible with the brz upright and ball joint.
And then spacing between the inner mounts is probably not the same anyway, and who knows what it would do to caster if they did actually line up. Probably would place the wheel too far back in the wheel well.
Cusco also makes arms that look pretty cool.
Captain Snooze 12-29-2016 12:15 AM
The SPL version looks pretty hot.
Attachment 147664
FastWhite 12-29-2016 12:32 AM
Try here!!
http://racerxfabrication.com/
