Old 12-09-2016, 12:02 PM   #15
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Originally Posted by Stang70Fastback View Post
Or maybe that's exactly what it was. Happens to me all the time with more aggressive steering inputs. Don't forget how much more tread squirm there is on winter tires.
I'm going to try to recreate this after work but that looks like it's going to be the answer.
Joon525 is offline   Reply With Quote
Old 12-09-2016, 12:25 PM   #16
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
May be lumps in the road surface between lanes.
The bots dots and dugouts for reflectors can change the relative speed between tires.
My BMW bike freaks out and cuts power whenever I pull over the central rumble strip when passing. Have to be aware.
Old 12-12-2016, 07:09 PM   #17
Joon525
Joon525's Avatar
Drives: 2016 BRZ
While this is indeed a case the road I was on didn't even have those.
I was able to recreate this same thing. I'm betting you can make this happen on non-winter tires as well but it's just easier with the softer sidewalls on winter rubber. Thanks again @Stang70Fastback
So to the future forum member who comes across this thread...it's most likely normal.
Old 12-12-2016, 08:02 PM   #18
justaturtle
I also have the same thing happen with my winter tires. 215/45/17 WS80's. It has gotten better now that I have had them on a month or so. The first few nights were just like that video. It will still get confused going fast around corners in the dry but nothing to worry about I believe.
justaturtle is offline   Reply With Quote
Old 12-12-2016, 08:13 PM   #19
The colder it gets the less it will happen. Winter tires are SOFT SOFT SOFT so that they can harden to the proper level when cold. That is what makes them winter tires. Such things as tread pattern and deep sidewalls that people associate with winter tires are actually secondary considerations.
Old 06-16-2020, 10:18 PM   #20
trinidadj
Drives: '16 FRS-MT Ablaze Red
Sorry for knocking the cob webs off this one. I'm having a similar issue to OP at highway speeds traction control will kick on lets sway on sweeping turns and overall the car feels very sensitive to steering inputs. My alignment, suspension set up, tire pressures are all good. The problem started AFTER I installed new rear tires about 5 days ago. The front tires are worn to 4/32 and new rear tires have been on for about 5 days with about 400 highway miles. Could the new rear be causing the issue? Thanks
trinidadj is offline   Reply With Quote
Old 06-16-2020, 10:45 PM   #21
soundman98
ProCrastinationConsultant
soundman98's Avatar
your car can see the difference in the speed of the tires and is reminding you that you're a cheapass.
replace all 4 tires.
Old 06-17-2020, 07:58 AM   #22
trinidadj
lol I don't think you can put cheap and pilot sport 4s tires in the same sentence. I autocross so I figured I could get one more run out of the ones up front but I guess they are heading for burnout island tonight lol. I'll get the other two put on this weekend and report back.
No traction control/ABS light on Hollwood_lives CANADA 6 01-13-2016 09:11 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
Traction control light at high RPM wizzo Issues | Warranty | Recalls / TSB 17 06-27-2015 05:18 PM
traction control and abs lights coming on after 20mins? UnLeasHer AUSTRALIA 28 02-23-2015 09:52 AM
ABS, Traction control and brake light??? JMoore412 Issues | Warranty | Recalls / TSB 18 08-20-2014 05:09 PM
