Old 07-22-2014, 08:35 PM   #1
JMoore412
Drives: 2014 Scion FRS, 2014 GTI, 2013 Golf
ABS, Traction control and brake light???
I was driving my car today which only has 210 miles on it and out of the blue the traction control light, abs light and brake light came on. I pulled over turned the car off hoping it would reset and nothing all the light are still on. The car is driving and braking fine with no issues. E brake switch is working because the driving lights come on when I release the e brake.
Anyone have this issue? All I have done to the car is Greddy intake, Evo 3 exhaust, B12 cup kit and 57DR wheels with PPS tires.
I checked all the fuses they appear to be fine.
JMoore412 is offline   Reply With Quote
Old 07-22-2014, 10:37 PM   #2
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
Seems to indicate a wheel speed sensor failure, or maybe low brake fluid? But that would normally only trigger the ABS light.
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
Old 07-22-2014, 10:41 PM   #3
Candlejack
Ignorance Intolerant
Candlejack's Avatar
Drives: '13 WRB BRZ Limited
Sounds like you need some $Free warranty work.
Candlejack is offline   Reply With Quote
Old 07-22-2014, 11:21 PM   #4
JMoore412
I am bringing it by the dealer tomorrow just worried the shop that did the B12 cup kit, wheels and top hats messed something up. Though I feel it's best to go to the dealer rather than them since I don't want them messing anything else up.
Old 07-23-2014, 07:07 AM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
It sounds like that install damaged a wheel speed sensor. Let's hope it's not.
N1rve
Old 07-23-2014, 10:01 AM   #6
JMoore412
I am guessing that will be the case I am rather pissed about this and taking it to the dealership this morning. Hopefully the shop that did the work is stand up enough if its not covered under warranty to cover it.
Old 07-23-2014, 10:17 AM   #7
NickDC88
NickDC88's Avatar
Used to own an IS300 that did this repeatedly during the summer. Never found out what it was, but from researching, it sounded like a wheel speed sensor problem, as previously stated.
NickDC88 is offline   Reply With Quote
Old 07-23-2014, 11:07 AM   #8
JMoore412
I am wondering it the 17x9 wheels with the PSS tires could be also causing and issue with the traction control.
Old 07-23-2014, 03:35 PM   #9
jdubz13frs
jdubz13frs's Avatar
Drives: 2013 Scion FR-S 6MT
Very unlikely. It may be nothing damaged, there have been other people on this forum with ABS and TRAC issues on brand new cars due to a computer issue. The dealer will let you know. If it is due to the other shop, they should definetly help you out.
jdubz13frs is offline   Reply With Quote
Old 07-23-2014, 08:04 PM   #10
JMoore412
Dealer called and said a wiring harness came loose which caused all the lights. Guessing the shop never plugged it back in all the way. Cost me $95.00 going to see if the shop that did work to it will cover the bill but I doubt it.
Old 07-23-2014, 08:33 PM   #11
mike the snake
Did you not like the shop any more? Why didn't you let them look at it?
Old 07-23-2014, 09:31 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Sounds like the shop is incompetent.
I never had to unplug any sensors to install my coilovers. Only time I had to unbolt anything was to remove my hubs to install long wheel studs, and that never involved unplugging the harness in its entirety.
-alex
Old 07-23-2014, 09:54 PM   #13
JMoore412
I was going to let the place that did it look at it but figured if they messed something up didn't want them to do anymore damage. I live in an area where there are no shops that will even do lowering springs. I called 15 places and this was the only place that would do it. We live in the sticks and unless it is a truck getting lifted no one wants to touch it.
Old 08-06-2014, 08:52 PM   #14
JMoore412
Got into my car after work and the ABS, traction and brake light where on once again. Turning the car off didn't fix the problem so back to the dealership I went. After 4 hours the master tech had to call the help line to figure out what could be wrong. They are now saying it is the abs actuator that is causing the issue. Has anyone heard of this happening?
Traction Control Light Constantly On Cal3000 Issues | Warranty | Recalls / TSB 26 12-25-2016 05:20 PM
First Check Engine Light and Traction control QFry Issues | Warranty | Recalls / TSB 26 10-04-2014 11:27 PM
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 01:04 PM
lowered car and traction control light came on Shipwreck Issues | Warranty | Recalls / TSB 2 11-05-2013 05:18 AM
hit a curb HARD, traction control and ABS light on now need help plz! EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 02-28-2013 04:08 PM
