CANADA Canada
Old 01-13-2016, 05:44 AM   #1
Hollwood_lives
Drives: 2015 Halo FR-S
No traction control/ABS light on
Reason for traction control to be permanent disengaged controls wot work no lights on only swerve light under rpm also abs light on. Anyone help me out and know why?
Hollwood_lives is offline   Reply With Quote
Old 01-13-2016, 05:49 AM   #2
swarb
1. check fuses
2. pull code
3. take it to the dealer
Old 01-13-2016, 09:20 AM   #3
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Dude check your airbag sensor when you took your steering wheel off
drewbot is offline   Reply With Quote
Old 01-13-2016, 09:28 AM   #4
Hollwood_lives
Air bag sensor is taken car of
Old 01-13-2016, 09:29 AM   #5
wparsons
wparsons's Avatar
ABS light on *might* mean there's something wrong in the ABS system...
Check if any codes are stored, and/or take it to the dealership.
flickr
Old 01-13-2016, 10:40 AM   #6
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
If you have an aftermarket steering wheel and in any way messed with or removed the clock spring underneath, I've heard this could be a cause.
Part of the reason why I switched back to my OEM wheel after only 3 days with a Nardi.
@bpennerz
SLVRSRFR is offline   Reply With Quote
The Following User Says Thank You to SLVRSRFR For This Useful Post:
Cole (01-13-2016)
Old 01-13-2016, 09:11 PM   #7
VirUzxZ
Drives: Black on Black on Black
I actually had this issue start last week. (the first heavy snow and then I guess it flash froze some of it?) Apparently Front Driver side ABS Speed Sensor Died/tore/broke/crappedout on me thus leaving me with Solid Slip light and ABS lights on.
I have an ODB Reader, No codes at all. Pulled and checked ALL checkable fuses under the hood and Under the steering wheel.
Gave up and took her to the dealer
Took a week to order the part and get replaced. All courtesy of the dealer.
Literally just picked her up from the dealer not more than 20 minutes ago
VirUzxZ is offline   Reply With Quote
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
ABS and Traction Control Light on -> ABS Actuator Went Out N1rve Issues | Warranty | Recalls / TSB 11 11-29-2015 08:35 PM
Traction control light at high RPM wizzo Issues | Warranty | Recalls / TSB 17 06-27-2015 05:18 PM
Traction control, abs and brake light all on? JMoore412 Issues | Warranty | Recalls / TSB 0 08-12-2014 07:27 PM
lowered car and traction control light came on Shipwreck Issues | Warranty | Recalls / TSB 2 11-05-2013 05:18 AM
