Old 06-21-2015, 02:45 AM   #1
wizzo
Drives: 2014 Toyota 86
Traction control light at high RPM
Hey all,
Got a check engine light at the track yesterday, it is for cylinder 1 misfires, going to take the car to dealer to get in done under warantee. This morning i also noticed that i have the traction control light comming on at high RPM, between about 5500 rpm to 7300 rpm the light stays on (Traction light inside the rpm gauge)
Anyone experienced the traction control light issue before?
wizzo is offline   Reply With Quote
Old 06-21-2015, 10:13 AM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Because the intelligent thing to do when you have a Check Engine Light for a misfire is to continue to drive the car at redline...
Stang70Fastback is offline   Reply With Quote
Old 06-21-2015, 10:52 AM   #3
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
car goes into limp mode i believe when you have check light. so it prevents to damage on engine
Old 06-21-2015, 01:18 PM   #4
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Totaled Motor.....
ntron1 is offline   Reply With Quote
Old 06-21-2015, 01:48 PM   #5
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
The car does go into limp mode with the cel... however it only helps limit the damage to your engine. You can still do more damage by driving higher up in the Rev range. I'm in shock that you would be driving above 5k rpm wit a potential misfire. I feel bad for your poor car.
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 06-21-2015, 02:08 PM   #6
stugray
Drives: 2013 GBS BRZ Limited
Also - if the CEL is related to timing, then the system might disable TCS as well depending on the specific problem.
WAG says you have a coil pack going out.
And yes - whenever you get a CEL you should hold the engine at redline as long as possible - helps with the diagnostics (I mean autopsy/post-mortem).
Old 06-21-2015, 05:27 PM   #7
wizzo
I actually tried this after i cleared the check engine and it had dissapeared, today i was logging timing to see if the car is pulling timing when the light comes on and infact it is but the CEL has not come back on.. ordered a coilpack today and just going to swap it out tomorrow to reduce downtime.. but main point is the car wasnt floored with the CEL on, it was after it cleared to see if problem was still there or it was just on the track for some reason..
Old 06-22-2015, 08:46 AM   #8
Originally Posted by wizzo View Post
Hey all,
Are you sure that's not your shift light?
Is it yellow/orange or red?
If your car is throwing a misfire code, the traction light will briefly flash once to indicate that a code was thrown. If it is STAYING ON, it means you are throwing multiple codes back to back at high RPM. Continuing to drive is not a good idea; you may have done some long term damage to your car.
Old 06-22-2015, 08:55 AM   #9
nivek111070
Drives: 2014 GB Scoobie BRZ
in for long term damage...
nivek111070 is offline   Reply With Quote
Old 06-23-2015, 07:29 PM   #10
Jase
Drives: Toyota 86 GTS Aero - White
I've got the same issue mate - sounds like you've got the coil pack problem as per the TSB at http://www.ft86club.com/forums/attac...9&d=1422657737 - CSG Mike's explanation of how this effects the TC light sounds plausible - I hope so, mine is at the dealer today getting this issue fixed, I'll get it back sooner if there is just one issue to fix! Take it in for warranty work under the TSB, and don't listen to the nannies proclaiming "imminent engine doooom!!!", but do take it easy if the coil pack is bad enough to misfire :-).
Jase is offline   Reply With Quote
Old 06-25-2015, 08:29 PM   #11
wizzo
Yeah man, CSG Mike was correct as usual
If theres one thing ive learned forums you have two kinds of people, those that are bored and have nothing better to do in their free time but make stupid comments, and those who actually give good input and help one another solve problems.
I replaced the coil pack and the traction light doesn't light up anymore. My logs showed the car was pulling timing, its wierd there was no CEL light and that it had disappeared, but got the issue fixed
Old 06-26-2015, 11:18 AM   #12
stugray
I troubleshoot billion dollar electrical systems for a living AND I slept at a Holiday Inn Express last night. :-)
The system uses timing to control the TCS.
If the ECU detects any problem with the ignition subsystem, it will disable TCS.
Old 06-26-2015, 12:41 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
thats the most random connection ever, like pushing my belly button to have my toes wiggle.
Old 06-26-2015, 01:17 PM   #14
stugray
It is not. The system uses ignition timing to reduce torque from the engine when the TCS system detects wheel slippage.
If there are any faults in the ignition system, TCS will NOT be operational.
Traction Control Light Constantly On Cal3000 Issues | Warranty | Recalls / TSB 26 12-25-2016 05:20 PM
ABS, Traction control and brake light??? JMoore412 Issues | Warranty | Recalls / TSB 18 08-20-2014 05:09 PM
Traction control, abs and brake light all on? JMoore412 Issues | Warranty | Recalls / TSB 0 08-12-2014 07:27 PM
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 01:04 PM
lowered car and traction control light came on Shipwreck Issues | Warranty | Recalls / TSB 2 11-05-2013 05:18 AM
