#29 | |
Drives: Full race 4cyl boxer
When the tech was inspecting the brakes and had the pads OUT, did he try to spin the wheel? If the resistance is there, it is a wheel bearing. If the resistance is NOT there, but comes BACK when he puts the pads back in, then it is the brakes. Simple process of elimination. Make them fix it. Tell them you don't feel safe driving the car "because if it is a dragging brake pad, it can boil the brake fluid" and when you go to jam on the brakes you have no brakes at all. If you make them think you are concerned for safety reasons, they HAVE to address the problem or it is a liability issue for them.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
#30 | |
#31 |
I reread the whole thread and I do not see anywhere that he said he modified the brakes.
#32 |
Drives: 2014 Subaru BRZ
#33 |
Look at the pic. Could be only paint but still enough for them to hang their hat on if they wanted to deny. If a wheel bearing they could argue the drop. Not saying it is right or that they would just that they could try!
#34 | |
![]() Maybe something to do with the brakes ...... ?? humfrz |
#35 | |
Drives: Slammed frs dark
Caliper are just paint, no modification at all and suspension was done where I work by a suspension specialist, I paint the caliper at the same time he did the suspension and grease my pad like 10 000km ago. Next week I will make the elimination process to see where the problem come from and them going back to a other dealer to get the problem fix, and I will record the whole thing just to be sure they don't tell me there no problem again. if they refuse I will directly make a complain to toyota! Thanks for your comments guys! I will keep you udpate
instagram ---> tehpepsi
#36 | |
#37 |
I hope you get it sorted out.
Yes, keep us updated. humfrz |
| Tags |
| brake, calipers, problem, wheels |
| Steering wheel resistance while threshold braking | Pat | Tracking / Autocross / HPDE / Drifting | 28 | 01-25-2017 08:50 PM |
| Header Rust resistance... | Skyllz | Engine, Exhaust, Transmission | 3 | 08-15-2016 11:55 AM |
| Shift resistance | natesparxxx | Engine, Exhaust, Transmission | 10 | 04-30-2014 10:23 PM |
| Shift resistance | amaciose | Engine, Exhaust, Transmission | 2 | 12-06-2013 08:53 PM |
| Brake resistance | Teo | Tracking / Autocross / HPDE / Drifting | 3 | 03-08-2013 03:03 PM |
