Old 06-02-2016, 08:29 AM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
Steering wheel resistance while threshold braking
Last weekend at the local track (High Plains Raceway) I experienced something I've never experienced before. When threshold braking the steering wheel provided me with significant resistance while threshold braking. There are a couple turns at High Plains Raceway at which it was very noticeable. In turns 2 and 6 it became an increasingly annoying problem and got worse the faster I went. These are both turns that I enter going around 70 or 80 mph (sorry, no data acquisition available).
I was braking hard going into the turns and pulling noticeably harder on the steering wheel to get the car to turn in. Then, still providing similar steering angle, I release the brakes slowly and feel significantly less resistance from the steering wheel. Even though the steering angle didn't change, the attitude of the car did, and it began to rotate much better. There seems to be some kind of correlation between the two.
Additionally, the car seems to understeer when this is happening. The front end just doesn't bite like I'm used to. As soon as I release the brakes, the front end just digs in and goes right where I want it to.
Keep in mind what I'm experiencing is not simply the car pushing. The car's attitude changes as soon as I feel less resistance in the steering wheel.
My car's stats as it sits now:
stock suspension
BFG R1S at 29 psi hot
Even tire temps all around except +15 degrees F on the front tires' inner shoulders
stock brakes other than DTC 60s and Togue Factory ducts
RCE street camber plates
Stock caster, 3.2* of front camber, zero toe
I'd like to stress that the front end seems to turn in properly when the steering wheels resistance went away, not when I released the brake pedal. Although they happened pretty much at the same time, it seemed to me the car's attitude changed depending on the resistance to the steering wheel and not specifically the brake pedal. I don't know why it felt that way to me, but it did.
Who else has experienced this? Any ideas why this is happening?
For what it's worth, my best lap last weekend was a 2:10.7 on an exceptionally slippery track. I'm guessing the best it was capable of was high 2:09s, but that would be really pushing it in this trim. Maybe that'll give any local guys more perspective and help with diagnosis.
Old 06-02-2016, 10:32 AM   #2
wparsons
wparsons's Avatar
I had this happen repeatably at CTMP (Mosport), on the GP track, going into 5a. I attributed it to how much load was on the left front wheel on the compression up the hill and turning in at the same time. Taking a different line stopped it entirely, and it didn't happen at slower speeds where less weight was transferred to the left front wheel. It wasn't understeering for me though, just heavy effort at the wheel.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Pat (06-02-2016)
Old 06-02-2016, 11:14 AM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
Interesting, thank you. 5a looks like it would put you in a situation similar to what I was in. Have you tried to figure out the cause of it? Dealing with this issue is kind throws a wet blanket on my desire to go faster.
Old 06-02-2016, 11:38 AM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
I've run into this at AutoX (I think it's the same thing) under similar situations, where one front corner was under heavy load. I've been lucky perhaps that it has happened after I was largely turned in and I didn't have it fighting me beyond making me have to muscle it through and a bit to exit... basically feels like power steering loss.
Old 06-02-2016, 11:42 AM   #5
strat61caster
strat61caster's Avatar
It is known.
http://www.ft86club.com/forums/showthread.php?t=8432 (first post)
http://www.ft86club.com/forums/showthread.php?t=74300
http://www.ft86club.com/forums/showthread.php?p=2301565
http://www.ft86club.com/forums/showp...postcount=3837
No idea why it happens, overheating or overloading and it shuts off to prevent damage seems the most reasonable.
Haven't heard any solutions, I don't think CSG experienced it and I think Element deleted the PS so you've gotta keep your fingers crossed for some other random person to have figured it out.
I've never had it happen.
Edit: Your second paragraph sounds like a symptom of electronic brakeforce distribution, not anything at all to do with power steering. Do you brake/pedal dance?
http://www.ft86club.com/forums/showthread.php?t=25494
That's probably the most relevant line of questioning.
ineedyourdiddly
Pat (06-02-2016)
Old 06-02-2016, 11:47 AM   #6
Icecreamtruk
Drives: Track preped NA FRS
Question, did you do the pedal dance to completely disable the electronics (except ABS)? I've run into this in the past but not so much lately. I started doing the pedal dance a while back but I cant recall if I stopped encountering this at the same time or if it is a coincidence. My driving style has changed quite a bit (for the better) so it might just be driver inputs on my side.
Old 06-02-2016, 11:48 AM   #7
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I've had it happen a LOT. It's rather unpleasant and disconcerting, but not sure what can be done.
FWIW it's entirely unrelated to braking, it's completely load based on the front end. I would lose power steering completely around the banking in the karussell corner at Shenandoah. Really unpleasant...
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
Pat (06-02-2016), strat61caster (06-02-2016)
Old 06-02-2016, 12:03 PM   #8
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks, cjd. Unfortunately the corner that causes it the most is a decreasing radius turn, which makes my situation the opposite of yours in that it happens well before most of the turning is completed.
Old 06-02-2016, 12:09 PM   #9
Trail braking without the pedal dance will cause this.
Understeering under braking/turning (trail braking) without the pedal dance is normal.
@Pat: Are you pedal danced?
86kahl (06-02-2016), Pat (06-02-2016)
Old 06-02-2016, 12:17 PM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
It is known.
As usual, I love reading your posts. Thank you very much for sharing all of that information. I searched but failed. Not a big fan of the search function on this site. And apparently my Google-fu is sub-par.
I'm going to check my sway bar for rubbing when I get some time. I think that is the most logical, but am not convinced that is the problem.
This was also very helpful:
sw20koch post
Yes, I always do the pedal dance.
The Following User Says Thank You to Pat For This Useful Post:
Old 06-02-2016, 12:18 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
Old 06-02-2016, 12:49 PM   #12
renfield90
The Stig's German cousin
Also worth noting, I feel our front suspension likes to bump steer a bit. Entirely possible for you to load a tire or take a line such that it essentially bump steers away from the direction you want to turn, so there's additional force to overcome.
Old 06-02-2016, 08:38 PM   #13
gatorac
Chin Track Event Manager
Drives: 15 Series Blue
I have this issue all the time. It happens when the suspension is loaded and you need the power steering the most. That past 2 weeks I was at 4 different tracks. At Watkins Glen it was at the toe and turn 10. It happened all over at Palmer. Pitt Race turn 7 brought it on. I didn't notice it at Mid Ohio.
I never felt it with stock tires. Once I went to a stickier tire I thought maybe the power steering fluid was low. It was then I learned we have electric power steering. I've learned to ignore it but I'm disappointed that a specific failure hasn't been found that we can actually fix.
I expect someone not pushing the car that hard on street tires may never encounter the issue. Especially if that track doesn't have those turns that add compression during turning. It is, no doubt, a loss of power steering boost. It is not related to heat as I've had it happen on the first lap. Not really any way to have it addressed under warranty as the tech will never be able to recreate the issue.
My car is a 2014. Maybe later models don't have the same issue?
Jim Pomroy Chin Track Days Event Manager.
15 Series Blue in white
18 Golf R
09 Comp Yellow NC
20 Gladiator tow vehicle.
gatorac is offline   Reply With Quote
The Following User Says Thank You to gatorac For This Useful Post:
DocWalt (06-05-2016)
Old 06-04-2016, 02:45 AM   #14
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
sw20koch post
Pat,
I was just looking at a couple of your posts and the issues you're having. One thing is your hot psi is way too low for an R1 / R1S on our cars. The recommended hot psi from BFG is 36-42psi for a 2700-3000lb car and the R1S really likes to be on the high side of that.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Steering issue under braking ! AJ PwR Tracking / Autocross / HPDE / Drifting 146 04-25-2023 05:47 PM
Blue carbon steering wheel and steering wheel trim... installed! Pointmutation Cosmetic Modification (Interior/Exterior/Lighting) 15 02-06-2017 11:20 PM
WTB after market steering wheel set up . Steering wheel, hub and quick release. Vroomin86 Want-To-Buy Requests 1 11-05-2015 06:44 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
Wheel Hop When Braking Hard Bonburner Scion FR-S / Toyota 86 GT86 General Forum 27 01-14-2013 09:31 PM
