Old 12-06-2013, 04:04 PM   #1
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
Shift resistance
I'm still moderately new to all of the mechanics involved in a MT, but lately I've noticed a bunch of resistance when shifting into first and second gears when the car is running.
If I try and force it into gear it will eventually lock in if I wiggle it left and right a bit, and I won't get any grinding (although I will hear a bit of a whirring noise as it slips into gear). With the car off, the shifts are perfectly smooth.
Has anyone else noticed this and/or is it a problem? Is this fixed with a change of hardware, trans oil, or technique?
Thanks!
amaciose is offline   Reply With Quote
Old 12-06-2013, 04:15 PM   #2
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
If its colder in your area, and this is the first time you've driven in the cold thats probably all it is.
lickitysplit is offline   Reply With Quote
Old 12-06-2013, 08:53 PM   #3
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
try replacing your tranny oil, factory oil is sheeeittty.
Motul/Redline Amsoil work nicely and im sure there are some others. gm synchromesh worked wonders on hondas, maybe that would work well in our trannies too?
DAN_BRZ is offline   Reply With Quote
Shift resistance going into gate (notchiness) 1Cor10:23 Engine, Exhaust, Transmission 14 12-06-2013 07:16 PM
noise when releasing clutch/shift resistance abutterman Issues | Warranty | Recalls / TSB 11 07-20-2013 09:23 AM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
Brake resistance Teo Tracking / Autocross / HPDE / Drifting 3 03-08-2013 03:03 PM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
