#29 | |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
![]() And you have 720 Form GTF1's too, wow I'm jealous of those (couldn't find any US suppliers -_-'). But that does look great, not noticeable in any way. Thanks!
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build Ceramic Coated Gruppe-S UEL/OP Konig Hypergrams RS4 200tw Koni Yellows, Eibach Springs Ferodo DS2500's
#30 |
Drives: 2013 Firestorm FR-S
Depends on the rest of the suspension, mainly the spring perch. If you buy a camber plate and are using the stock spring perch it will likely add some noticeable height if you're on stock dampers, or severely limit height adjustment if you're on coilovers that didn't come with their own aftermarket spring perch.
"Shark_Bait88, the man whos spent the most money modding his stock FR-S and its still stock." -@jdnguyen
#31 |
Mountain Runner
That's a good point @Shark_Bait88, what spring perch did you use @Cole?
#32 | |
Not a troll
#33 |
The camber plates @Cole has look more recessed into the shock tower like the OE top mounts are though, so I'd imagine they'd likely work better with the OE perches vs. a flatter plate like the RCEs.
These are my SACHS coilovers when I had the RCE plates on them with the OE spring perch:
#34 | |
86
Have a set coming in the post and was after feedback.. |
#35 |
Not a troll
| Camber plates with stock struts | kbye | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 04-29-2016 01:37 AM |
| SOLD: Pre-assembled stock struts with RCE Yellows + Whiteline Com-C top mounts | ATL BRZ | Brakes, Suspension, Chassis | 12 | 08-07-2014 09:23 PM |
| Front stock struts/bolts max camber Q.. | OICU812 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-15-2013 04:45 PM |
| FS: RCE Yellows on stock struts (complete package) | sw20kosh | Brakes, Suspension, Chassis | 6 | 07-02-2013 05:02 PM |
| RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings | raul | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 05-24-2013 08:33 AM |
