Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings
Spent a few hours doing this yesterday. The drop is subtle, but it rides amazing! I have the Konis set one full turn from full soft and will be fine tuning as I drive it more. Since I knew I was going to need to cut my front struts I decided to get an extra set from an ex-FR-S owner I knew in case I botched it up. The process was pretty straight forward but I wasn't trying to make a DIY so I didn't take many pictures.
![]() Stock on top, RCEs on the bottom:
Drives: Fr-s MT Ultramarine
Would love to hear more driving impressions compared to stock!
Thanks |
Lap time enthusiast
That Guy
Drives: 2013 asphalt FRS MT
I just installed yellows and some bushings. I DD my can and was really worried about making the ride worse and lower the car too much. I can't believe how well these ride, even on the stock struts. Considering they are about 100% stiffer in the front I was nervous.
The extra spring rate in the front does a great job of keeping the car off the bump stops, which makes driving at the limit much easier and confidence inspiring. RCE really did a great job picking these rates and not going with the trend of just increasing the stock rates proportionately. |
#5 | |
Drives: Attitude
Getting an alignment tomorrow. Pretty sure it's my "alignment" (lol, stupid camber in the rear and probably some dumb toe up front), but traction control was kicking in a lot more frequently. It may also be in part to my "alignment," but the car really wants to change directions now. Not uncontrollably so, but much more directly. |
#6 | |
That Guy
Lap time enthusiast
@OrbitalEllipses
I dialed in 1 full turn both front and rear and the car was actually pretty neutral. It also rode very nice compared to stock. You had to really push it to get the tail to slide. I dialed it back about a quarter turn in the rear and now I can rotate the car a bit easier with throttle. So far that seems to feel the best pre-alignment. We'll see how it goes post-alignment. |
#8 | ||
Drives: Attitude
Also mini-review of the SPC arms: they are not RH or LH specific (as a cost saving measure I'm sure). Take from that what you will. |
#9 | |
That Guy
What model subaru top hat is required for the Group-N tops? I thought it was the same as the bugeye's (sorry, I'm not familiar with the chassis codes) but that they were clocked differently. Do they change the strut position at all? |
#10 |
Drives: BRZ and NA
I put my car on the same setup. You can read about it here: http://www.ft86club.com/forums/showthread.php?t=32187
#12 | |
Drives: Attitude
#13 | |
That Guy
#14 |
Lap time enthusiast
Went around for some figure 8s tonight at a local deserted parking lot. Ended up 1.25 turns from soft in the front and 1 full turn in the back. It corners neutral for the most part, but if you add throttle mid-corner you can get the car to rotate in a very controlled, progressive manner. It's still slightly bouncy and I might play with it more later, but so far it feels amazing.
| Adjustable Camber Arms vs. Whiteline Camber Bushings | digital_assassin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 70 | 06-02-2013 06:06 AM |
| FS: rce yellows & whiteline camber bolt $300 | chappys4life | Mid-Atlantic | 19 | 05-13-2013 02:31 PM |
