Old 11-29-2016, 01:48 AM   #29
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Originally Posted by Cole View Post
Here's a picture of mine, just for some extra confirmation. Not the best picture, but you get the idea.
And you have 720 Form GTF1's too, wow I'm jealous of those (couldn't find any US suppliers -_-'). But that does look great, not noticeable in any way. Thanks!
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 11-29-2016, 09:47 AM   #30
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by baorz View Post
Honestly, if you add camber plates, the change in ride height probably won't be noticeable.
Depends on the rest of the suspension, mainly the spring perch. If you buy a camber plate and are using the stock spring perch it will likely add some noticeable height if you're on stock dampers, or severely limit height adjustment if you're on coilovers that didn't come with their own aftermarket spring perch.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 11-29-2016, 12:40 PM   #31
Keenercarguy
Mountain Runner
That's a good point @Shark_Bait88, what spring perch did you use @Cole?
Old 11-29-2016, 01:36 PM   #32
Cole
Not a troll
Cole's Avatar
The one from the stockers, I believe.
Cole is offline   Reply With Quote
Old 11-29-2016, 02:06 PM   #33
Shark_Bait88
The camber plates @Cole has look more recessed into the shock tower like the OE top mounts are though, so I'd imagine they'd likely work better with the OE perches vs. a flatter plate like the RCEs.
These are my SACHS coilovers when I had the RCE plates on them with the OE spring perch:
Old 06-19-2017, 06:02 AM   #34
Boomerang
86
Boomerang's Avatar
Are the silver project plates still going strong/no issues?
Have a set coming in the post and was after feedback..
Old 06-19-2017, 07:53 AM   #35
Cole
Not a troll
Cole's Avatar
I think they the bearings are still going to be the weak link, but no issues so far
Camber plates with stock struts kbye Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-29-2016 01:37 AM
SOLD: Pre-assembled stock struts with RCE Yellows + Whiteline Com-C top mounts ATL BRZ Brakes, Suspension, Chassis 12 08-07-2014 09:23 PM
Front stock struts/bolts max camber Q.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-15-2013 04:45 PM
FS: RCE Yellows on stock struts (complete package) sw20kosh Brakes, Suspension, Chassis 6 07-02-2013 05:02 PM
RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings raul Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 05-24-2013 08:33 AM
