Old 10-14-2013, 11:51 PM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Front stock struts/bolts max camber Q..
Ok so trying to help a friend who's researching offsets. I have coils so I honestly don't know what max (-) camber can be achieved with stock front struts/bolts with stock top hats. For anyone with fresh knowledge on this Q I'd appreciate it. I went through posts for last hr and couldn't locate a answer on this.
Thanks.
Old 10-15-2013, 12:07 AM   #2
aCab
aCab's Avatar
Drives: FR-S & S2k
My car all stock with whiteline camber bolts was around -1.75 degrees up front
Bilstein Damptronic Prototypes | Other silly bits
aCab is offline   Reply With Quote
Old 10-15-2013, 12:08 AM   #3
OICU812
Just a dude
OICU812's Avatar
Ok thanks any idea on what stock bolts can get?
Old 10-15-2013, 12:18 AM   #4
aCab
aCab's Avatar
Drives: FR-S & S2k
Stock camber is non-adjustible. Were you referring to the subaru crash bolts?
Old 10-15-2013, 12:54 AM   #5
OICU812
Just a dude
OICU812's Avatar
Ok not adjustable so he'll need either the WL bolts or these crash bolts you speak of then correct? Is one of those options better then the other?
Old 10-15-2013, 01:00 AM   #6
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
for the oem bolt yes they are non adjustable but there are hole tolerances that if you loosen them and let the wheels tip in under the weight of the car you can get max -0.6 degrees. this is what I got until i swapped out the upper bolts. if you use a lower 14mm or a 9/16(what I did) bolt in the upper hole you can get max -1.3 degrees.
garfull is offline   Reply With Quote
Old 10-15-2013, 05:34 AM   #7
OICU812
Just a dude
OICU812's Avatar
Anyone know part # for crash bolts?
Old 10-15-2013, 03:52 PM   #8
brz7400
brz7400's Avatar
Drives: Subaru BRZ
1 year old post maybe hidden too far back, here you go.
http://www.ft86club.com/forums/showthread.php?t=18865
brz7400 is offline   Reply With Quote
Old 10-15-2013, 04:45 PM   #9
CSG David
CSG David's Avatar
Subaru crash bolts will get you between -0.7 to -1.4. Everybody has a weird number. Our car got -1.1 and was seriously not enough.
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Why doesn't it come like this from the Factory? (Front Camber Bolts + Spring Swaping) Kostamojen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-05-2013 01:20 AM
SPC/Whiteline front camber bolts in GTA? f0rge CANADA 2 03-20-2013 10:56 PM
replace front crash bolts to add camber? Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-15-2012 10:05 AM
