Old 08-21-2015, 12:46 PM   #1
kbye
kbye's Avatar
Drives: 2014 FR-S
Camber plates with stock struts
Is the OEM conical washer required when using the stock spring perch with camber plates? (in my case it's Beatrush)
I've got conflicting answers in my research. The stock spring perch is supposed to have a welded-in washer therefore negating the GD style washer. BUT, some are saying that the washer helps with binding/clunking and relieves stress on the pillowball.
So, what's the consensus out there? I'd rather not raise my height by 5mm if I don't need the washer.
kbye is offline   Reply With Quote
Old 08-26-2015, 12:28 AM   #2
kbye
kbye's Avatar
Drives: 2014 FR-S
Alright since no one replied, I got off my lazy ass to find out myself.
For anyone who comes across this in the future, the answer is no. There is no need for a conical washer with the stock spring perch.
Old 09-16-2015, 02:10 AM   #3
kbye
kbye's Avatar
Drives: 2014 FR-S
Still on the topic of camber plates with stock struts... I switched to Raceseng because the Beatrush plates raised the ride height too much.
Here's where I encountered an issue. I was unable to increase camber beyond two markings on the plate, and I had no idea why.
Then I played around with the other plate and discovered the reason...
Because the OEM-sized spring perch is 90mm, it's so wide that it interferes with the strut tower bolt. This issue would never occur with coilovers, because they would have smaller spring perches.
After messing around with it, I found that I was able to increase my camber range at the expense of caster. By moving the plate towards the front (therefore decreasing caster), the strut tower bolt position gives more room for the perch to swing back.
My camber setting until I get an alignment:
And here's how much clearance is between the strut tower bolt and the spring perch. I am debating just throwing in the towel and going back to coils, but we'll see how this setup plays out.
I measured the height from ground to fender before and after: 654mm with OEM top hats, 655mm with the raceseng plates, so my ride height remained unchanged.
Overall I'm quite happy with the plates, they gave me an acceptable camber range (although I did have maxed out OEM camber bolts as well), they're well crafted and ride quite nicely.
I hope this will be useful for anyone looking to use the Raceseng cascam with OEM sized spring setups.
Old 09-16-2015, 08:18 AM   #4
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
I had the same issue. The bolts are too long. Give them a call. The wonderful fellas at Raceng will get you the proper length bolts.
BatStig is offline   Reply With Quote
Old 09-16-2015, 11:13 AM   #5
strat61caster
strat61caster's Avatar
Yup, you got sent the wrong length bolts, mine are barely protruding out the bottom (probably less than two threads) and I have no problem going all the way to maximum negative on my cascam's. (Also on stock springs and dampers)
Call Raceseng.
Edit: Or if you're impatient and have a grinder or hacksaw/file...
ineedyourdiddly
Old 09-16-2015, 11:40 AM   #6
Kayshart
Why does the beatrush raise ride height?
Kayshart is offline   Reply With Quote
Old 09-16-2015, 11:47 AM   #7
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
We just shaved them.....it was too late to go back and install everything when I also encountered this same issue
drewbot is offline   Reply With Quote
Old 09-16-2015, 12:31 PM   #8
strat61caster
Look up at post #2, the distance between the camber plate (which is where it sits in the strut tower) and where the spring is located. The stock top mounts allow the spring perch, and therefore the spring to nestle up inside the strut tower better giving you the stock ride height. The Beatrush design pushes the spring away from the car. It's a simple cost effective design that isn't a problem if you're pairing it with a lowering spring/coilover.
Raceseng has a custom spring perch and spring perch bushing to give their setup near OEM ride height. (Just one reason their setup is $100+ more expensive than others)
(coincidentally, OP can see in the below picture that he was given the wrong length of screw)
ineedyourdiddly
Old 09-16-2015, 01:26 PM   #9
kbye
kbye's Avatar
Drives: 2014 FR-S
Basically what @strat61caster said, the beatrush has a low mount design which is fine if you're running height-adjustable coilovers but not great with the OEM spring perch. Raceseng is also a low-mount design but their own spring perch minimizes the stack height distance, resulting in no ride height change.
I've contacted Jarrett for the shorter bolts, thanks guys! That should've been the first thing I thought of.
Old 02-01-2016, 04:19 PM   #10
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
Does anyone know if the Raceseng spring perch will work with other camber plates? The spring perch and bushing are available to purchase separately on their site.
I'm not sure if the Raceseng bushing will fit into another camber plate, however, I don't see why you couldn't use their low profile spring perch with an oem style conical washer.
avishenoy1 is offline   Reply With Quote
Old 04-28-2016, 05:44 PM   #11
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Sorry to resurrect an old thread, but I'm currently dealing with this issue too.
Did you ever figure this out?
I've got RCE camber plates on my SACHS coilovers, but they use the OE spring perches. With my fronts as low as they can go it's still sitting fairly high, because of how tall the OE spring perch is versus an aftermarket perch.
I don't want to go much lower, only about another 1/2", but that won't happen with the OE spring perches.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 04-29-2016, 01:37 AM   #12
avishenoy1
avishenoy1's Avatar
I ended up just buying the Raceseng cascam plates so I'm not sure. You could buy the perches and if they don't fit, return them?
Alignment with stock suspension + camber plates Pat Tracking / Autocross / HPDE / Drifting 9 08-18-2015 12:39 PM
FS: HVT Non-raising camber plates & WL camber bolts trippinbillies40 Brakes, Suspension, Chassis 1 05-16-2015 09:00 PM
Front stock struts/bolts max camber Q.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-15-2013 04:45 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 08:51 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
