Old 11-21-2016, 09:27 PM   #15
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by Kaotic Lazagna View Post
http://www.platts.com/latest-news/oi...uests-21401095
They still receive varying blends of gas. May as well call it winter blend since it's different from summer blend.
I am guessing at the abbreviations but it looks like they mandate a lower vapour pressure fuel for summer in FL.
Winter gas where I am has additives to prevent things like potential gas line freezing issues. Yours is probably just regular gas with the summer fuel having something different to reduce vapour emitted in high temperatures.
Old 11-21-2016, 09:31 PM   #16
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Originally Posted by VeganGirl View Post
Is this normal? Immediately after installing wider rims and tires(I'm going forced induction some time next weekish) I noticed my average kept dropping and dropping slowly over a few weeks. It was at a consistent 27-28, now it's 19-20 and will not go above 21. Is that normal?
LOL !!!
Yes. Heavy ass wheels would do that. But hey those 18"+ wheels sure look good eh?
As others said wait till you boost.
Old 11-21-2016, 10:48 PM   #17
Kaotic Lazagna
Drives: GR Corolla
I'm sure you guys up there get way more things in your winter blend than we do since you guys have to deal with below freezing temperatures. But I do see a mpg hit once my local gas stations switch over to winter blends.
Old 11-21-2016, 11:21 PM   #18
VeganGirl
Drives: Scion FR-S 2013
I don't know the exact specs on my wheel. I know they are 18 inches by 9.5 back and 18 inch by 8.5 front and they are rays gram light 57xtremes. My love drives his car with 11inch tires in the back and kraftwerks c30 and his mileage is 19-20. I hope when I out my edelbrock kit it doesn't drop down to like 15 or something. I live in Florida and I haven't changed my driving habits. Me and bf both drive automatics and daily our cars. I don't really know if anything else that would have caused my mpg to drop so bad cause I only noticed it after putting the rims, but to me they feel almost the same weight as stock or lighter, they don't feel heavier but I could be wrong . I am not mechanically inclined at all soo...
VeganGirl is offline   Reply With Quote
Old 11-22-2016, 12:47 AM   #19
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
57extremes in 18x9.5 are approximately 21.6 lbs, while the stock wheels are around 20.1 lbs.
[ame="https://www.youtube.com/watch?v=kHEDacBb9hA"]RAYS Engineering Gramlight 57Xtreme Review/Weight + Colour Display - YouTube[/ame]
http://www.ft86club.com/forums/showthread.php?t=4075
What kind of tires did you get?
I just went FI with the Edelbrock kit and so far I'm almost near my 30 MPG that I used to get while NA on 91 octane with my same driving habits.
menikmati is offline   Reply With Quote
Old 11-22-2016, 12:49 AM   #20
Kaotic Lazagna
Drives: GR Corolla
Maybe a stupid question, but are your tires directional? If so, are they pointed forwards?
I don't know how an alignment would get drastically affected by a wheel swap, but if your alignment somehow got messed up, that can also contribute to the lower mpg.
Lastly, check your tire pressure and make sure they're not on the lower side.
Did you switch gas stations and/or brands lately?
Old 11-22-2016, 07:31 AM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
FIRSTLY, check tire pressures. That's the only thing that would result in such a drastic loss and also would explain why it got worse over time.
This is the OBVIOUS first thing to check, yet it took til post #20 for someone to casually mention it might be worth checking *lastly*?!
Old 11-22-2016, 08:36 AM   #22
VeganGirl
I don't know how to tell if they are directional is there anything i would see on the rim that would tell me? My tires say max pressure 50, and my car says 35, I keep them at 39. I think that's good enough? When they warm up the pressure increases right? Also no I didn't change gas stations. I always put 93 shell gas only.
Old 11-22-2016, 08:40 AM   #23
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
On the sidewall it will have large lettering saying DIRECTION and an arrow pointing the way they should be rotating. It should point towards the front of the car.
Tire pressure is subjective, but most people run between 32-34 for daily driving. At 39, that is actually probably overinflated.
Old 11-22-2016, 09:18 AM   #24
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
39 would be better for gas mileage.
why? is offline   Reply With Quote
Old 11-22-2016, 09:24 AM   #25
Kaotic Lazagna
Drives: GR Corolla
I run between 38 to 40 psi (cold). 52k miles, ~45k of which are the OEM tires. Tires have even wear across the tread.
The tire may also say "outside" on the side wall in addition to "direction >."
Only thing I can think now is some how the alignment (unless you've been driving around with the AC on the entire time [having the front defroster on will turn on the AC compressor]).
Also, are your mpg numbers calculated by hand, or are you going off your digital gauge?
Old 11-22-2016, 09:33 AM   #26
Summerwolf
Panda Trueno
Summerwolf's Avatar
Good call on the OUTSIDE marking as well.
http://tires.tirerack.com/tires/Tire%20Pressure%20Chart
There is a good reference on tire pressure.
The Following User Says Thank You to Summerwolf For This Useful Post:
Kaotic Lazagna (11-22-2016)
Old 11-22-2016, 11:37 AM   #27
VeganGirl
I did not get an alignment after putting these rims on, I did get an alignment maybe like a few months before I put them on when I got lowering springs, but that was stock rims and tires. I thought if the car still drove fine I didn't need an alignment. It doesn't veer of to one side or anything.
I will check the direction when I get out of work
Old 11-22-2016, 11:46 AM   #28
jasonojordan
Drives: 2013 satin white brz limited
Please for the love of Christ stop calling them rims
jasonojordan is offline   Reply With Quote
The Following 4 Users Say Thank You to jasonojordan For This Useful Post:
brzbrad (12-05-2016), Hostile_Kittens (11-23-2016), why? (11-22-2016), Yardjass (11-23-2016)
FS: OEM tires and rims - Stock rims and tires Webster10 Wheels and Tires 14 11-16-2015 05:50 PM
Gas mileage decrease on wider tires? donoman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-17-2015 08:54 PM
question on putting my tires in the storage tYtEn86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-15-2014 01:23 PM
Does anyone regret putting stickier tires on? unsurety Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 05-14-2014 03:50 PM
245 or 255 bad tires + light rims = 225 mid-gripy tires + normal rims? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-18-2013 02:33 PM
