Old 11-21-2016, 03:38 PM   #1
VeganGirl
Drives: Scion FR-S 2013
After putting on after market rims and tires my gas mileage went from 28 to 20?
Is this normal? Immediately after installing wider rims and tires(I'm going forced induction some time next weekish) I noticed my average kept dropping and dropping slowly over a few weeks. It was at a consistent 27-28, now it's 19-20 and will not go above 21. Is that normal?
VeganGirl is offline   Reply With Quote
Old 11-21-2016, 03:42 PM   #2
Yes.
Wait 'till you get FI on there!
AJPG (11-22-2016), go_a_way1 (11-21-2016), PandaSPUR (11-22-2016)
Old 11-21-2016, 04:00 PM   #3
86Boyz
Drives: on the highway to hell
What kinda whims did you get? Similar to this?
86Boyz is offline   Reply With Quote
The Following 4 Users Say Thank You to 86Boyz For This Useful Post:
6-Shift (11-23-2016), DAEMANO (11-21-2016), meWant (11-21-2016), Yardjass (11-23-2016)
Old 11-21-2016, 04:01 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yes.
OMG THIS SO MUCH!!!!
Fuel economy sucks total balls with the turbo now. 12L/100km highway is good for me now its lol. Its fun but cost too much in gas now
Old 11-21-2016, 04:13 PM   #5
jasonojordan
Drives: 2013 satin white brz limited
Well there are alot of things to consider here.
1. Whats the Size of the new wheels (Rims as you call them)
2. How much does the new wheels weight.
3. How wide are the new wheels.
4.How wide are the new tires?
Thats the short version of the list of why did my gas mileage go in the shitter.
jasonojordan is offline   Reply With Quote
Old 11-21-2016, 04:35 PM   #6
Kaotic Lazagna
Drives: GR Corolla
In addition to wheel weight and tire weight, you have to factor if the new tires have a higher traction rating than the tires they replaced. More traction means more grip, which means drop in fuel economy.
One other consideration is the gas. Your area may have switched over to winter blend, which will give a drop in mpg.
I have the same mpg as the OEM wheels and tires when I have my 17x9 TC105N with 245/40/17 Continental tires.
Old 11-21-2016, 05:58 PM   #7
cjny
Drives: 2016 BRZ
Yes, larger tires will measurably lower your gas mileage, but likely not that much. Consider other factors that might contribute.
cjny is offline   Reply With Quote
Old 11-21-2016, 06:17 PM   #8
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
This is because 17x9 on TC105N with 245/40/17 is almost the exact same weight as the stock setup.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 11-21-2016, 06:20 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
Heavier wheels/tires and more roll resistance arent going to reduce mileage by almost a third. And, there isn't the need for winter gas in FL. LOL
Im going to go with a heavy foot, multiple short trips and possibly the ethanol content of the fuel you used might be higher than previously.
Old 11-21-2016, 06:20 PM   #10
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
That's way too large of a drop in gas mileage.. something is wrong
unless your car looks like this
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
Old 11-21-2016, 07:39 PM   #11
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
TireRack measures fuel efficiency in their tire tests. The differences in efficiency between similar tires can be surprising. For example, there was a 5.3% difference between the best and worst tire in this Max Performance summer tire test:
http://www.tirerack.com/tires/tests/...y.jsp?ttid=218
Note that this test is done with tires of identical size.
Now if you were to go from a low rolling resistance narrow tire like the stock Primacy on stock wheels to a much wider, stickier, heavier tire mounted on heavier wheels, I would expect a significant reduction in fuel economy. The wheels and tires probably aren't the only factor, but I wouldn't be surprised if it accounted for 2/3 of the drop.
C4RBON is offline   Reply With Quote
The Following User Says Thank You to C4RBON For This Useful Post:
strat61caster (12-22-2016)
Old 11-21-2016, 08:12 PM   #12
Kaotic Lazagna
Drives: GR Corolla
Lol. That was my point for the OP. It's hard for us to say anything without more info.
Old 11-21-2016, 08:18 PM   #13
Kaotic Lazagna
Drives: GR Corolla
LOL.
http://www.platts.com/latest-news/oi...uests-21401095
They still receive varying blends of gas. May as well call it winter blend since it's different from summer blend.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Old 11-21-2016, 09:12 PM   #14
df.dima
Drives: FR-S and Mazda 3 Sky
I was getting close to 27-28 stock as well and with wider/stickier tire I get 24.5 (245 MPSS on x9 light weight wheel). Dipping beyond 20 seems pretty excessive, but depends on the way you drive I guess is possible, or you have some other factor. I can't imagine you drove aggressively and got 28mpg on stock, similarly, I expect you don't drive much different with wider tires now.
df.dima is offline   Reply With Quote
The Following User Says Thank You to df.dima For This Useful Post:
FS: OEM tires and rims - Stock rims and tires Webster10 Wheels and Tires 14 11-16-2015 05:50 PM
Gas mileage decrease on wider tires? donoman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-17-2015 08:54 PM
question on putting my tires in the storage tYtEn86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-15-2014 01:23 PM
Does anyone regret putting stickier tires on? unsurety Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 05-14-2014 03:50 PM
245 or 255 bad tires + light rims = 225 mid-gripy tires + normal rims? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-18-2013 02:33 PM
