Old 03-17-2015, 05:47 PM   #1
donoman
donoman's Avatar
Drives: '13 FR-S
Gas mileage decrease on wider tires?
Hey guys
I'm thinking about new wheels/tires for the FRS but concerned about which width to get. The stock tires have enough grip for me. I would like a tire that rides better, quieter, and maintains MPGs. Wider tires tend to grip more but I am mostly interested in new wheels/tires for looks and weight reduction. However it seems like a lot of the styles I want don't come in the stock rim width. I like the wheel to look flush.
Have any of you been able to maintain 30MPG on aftermarket wheels / tires?
donoman is offline   Reply With Quote
Old 03-17-2015, 05:54 PM   #2
gramicci101
Off Topic
The wheel looking flush is more a character of offset than tire width. I have the OEM wheels with 20f/25r mm spacers and mine fill the wheel well nicely.
Everything I've read says that wider tires will decrease your gas mileage. If you'd like to have a more flush look with similar width tires, look into a 17x8 or 18x8 with a 35mm offset and 225/45-17 or 225/40-18 tires. Michelin Pilot Super Sports come in both sizes. So do most other decent brands.
Old 03-17-2015, 06:08 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.tirerack.com/tires/tirete....jsp?techid=29
Old 03-17-2015, 06:32 PM   #4
swarb
Everyone's definition of flush is different. My mpg has been changed more by more city driving(vs highway) than the change in tire width/weight. With the same commute and the wheel/tire change, it is roughly the same, less than 1mpg difference. Driving habits make the most difference imo.
Old 03-17-2015, 07:20 PM   #5
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Yes I have 17x9 Weds and average 30mpg on a manual BRZ that I use for commute if I don't take it for a weekend drive in the mountains.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 03-17-2015, 07:25 PM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I was able to pull of 30mpg with 18x9 and 245/40/18
Pretty consistantly, not just one time while going downhill lol.
And I got 30mpg CALCULATED mpg, not the estimate by car
Old 03-17-2015, 08:54 PM   #7
donoman
donoman's Avatar
Drives: '13 FR-S
Thanks guys that's very encouraging!
On my 911 I put 275's on the back and gas mileage dropped from 18-19 to 15-16. Of course with the new tires came different driving sessions ;-). I also had an Insight and gas mileage dropped from 65 to 50 MPG when going from stock LRR tires to some sticky rubber... But that car only had 65HP.
Wider tires on stock wheels buzznasa Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 01-21-2019 01:55 PM
Camber or wider tires? Khyron686 Tracking / Autocross / HPDE / Drifting 8 05-27-2014 09:27 PM
Is understeer harder to regain control with wider tires? dem00n Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 03-27-2014 08:00 PM
Steering feel with wider tires? TSY Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 07-26-2013 10:32 AM
What would make the rear tires look wider?? Razor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-18-2013 11:16 PM
