| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Scion FR-S 2013
After putting on after market rims and tires my gas mileage went from 28 to 20?
Is this normal? Immediately after installing wider rims and tires(I'm going forced induction some time next weekish) I noticed my average kept dropping and dropping slowly over a few weeks. It was at a consistent 27-28, now it's 19-20 and will not go above 21. Is that normal?
#2 |
Yes.
Wait 'till you get FI on there!
#3 | |
Drives: on the highway to hell
#4 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
OMG THIS SO MUCH!!!!
Fuel economy sucks total balls with the turbo now. 12L/100km highway is good for me now its lol. Its fun but cost too much in gas now
#5 |
Drives: 2013 satin white brz limited
Well there are alot of things to consider here.
1. Whats the Size of the new wheels (Rims as you call them) 2. How much does the new wheels weight. 3. How wide are the new wheels. 4.How wide are the new tires? Thats the short version of the list of why did my gas mileage go in the shitter. |
#6 |
Drives: GR Corolla
In addition to wheel weight and tire weight, you have to factor if the new tires have a higher traction rating than the tires they replaced. More traction means more grip, which means drop in fuel economy.
One other consideration is the gas. Your area may have switched over to winter blend, which will give a drop in mpg. I have the same mpg as the OEM wheels and tires when I have my 17x9 TC105N with 245/40/17 Continental tires. |
#7 |
Drives: 2016 BRZ
Yes, larger tires will measurably lower your gas mileage, but likely not that much. Consider other factors that might contribute.
#8 |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
This is because 17x9 on TC105N with 245/40/17 is almost the exact same weight as the stock setup.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
#9 |
Sarcastic SOB
Heavier wheels/tires and more roll resistance arent going to reduce mileage by almost a third. And, there isn't the need for winter gas in FL. LOL
Im going to go with a heavy foot, multiple short trips and possibly the ethanol content of the fuel you used might be higher than previously.
#10 |
Drives: 2014 Subaru BRZ
That's way too large of a drop in gas mileage.. something is wrong
unless your car looks like this
| The Following User Says Thank You to VIP BRZ For This Useful Post: | 6-Shift (11-23-2016) |
#11 |
Drives: '15 BRZ, '19 GTI
TireRack measures fuel efficiency in their tire tests. The differences in efficiency between similar tires can be surprising. For example, there was a 5.3% difference between the best and worst tire in this Max Performance summer tire test:
http://www.tirerack.com/tires/tests/...y.jsp?ttid=218 Note that this test is done with tires of identical size. Now if you were to go from a low rolling resistance narrow tire like the stock Primacy on stock wheels to a much wider, stickier, heavier tire mounted on heavier wheels, I would expect a significant reduction in fuel economy. The wheels and tires probably aren't the only factor, but I wouldn't be surprised if it accounted for 2/3 of the drop. |
| The Following User Says Thank You to C4RBON For This Useful Post: | strat61caster (12-22-2016) |
#12 |
Drives: GR Corolla
#13 | |
Drives: GR Corolla
They still receive varying blends of gas. May as well call it winter blend since it's different from summer blend. |
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | strat61caster (12-22-2016) |
#14 | |
Drives: FR-S and Mazda 3 Sky
| The Following User Says Thank You to df.dima For This Useful Post: | Yardjass (11-23-2016) |
| FS: OEM tires and rims - Stock rims and tires | Webster10 | Wheels and Tires | 14 | 11-16-2015 05:50 PM |
| Gas mileage decrease on wider tires? | donoman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-17-2015 08:54 PM |
| question on putting my tires in the storage | tYtEn86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-15-2014 01:23 PM |
| Does anyone regret putting stickier tires on? | unsurety | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 05-14-2014 03:50 PM |
| 245 or 255 bad tires + light rims = 225 mid-gripy tires + normal rims? | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-18-2013 02:33 PM |
