Drives: 2017 Toyota 86 Halo
Question regarding Hill-start assist control
I apologize if this in the incorrect section, I had no idea where to post this question.
On the 2017 Toyota 86 it comes with Hill-start assist control which is disabled by default according to the manual. It seems logical to turn it on as it sounds useful, although it mentions to not depend on it with icy roads (common sense). Im not familiar with this feature nor incredibly automotive savy therefore I wonder is this something I want enabled and should I disable during winter months? Thanks for any input Sent from my D5803 using Tapatalk |
#2 | |
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | 8RZ (09-28-2016), go_a_way1 (09-28-2016), humfrz (09-28-2016), rkaywhodat (09-28-2016), Summerwolf (09-28-2016) |
#3 |
Drives: '05 Elise
Agreed with Tcoat.
My 500 Abarth was the first car I owned with hill start, so I tried it. I felt it was harder to drive smoothly on hills with it on than with the system disabled. It holds the brake for you in order to let you get in gear before rolling back, but what that does is it sometimes requires you to give it more throttle than needed to disengage the braking. If you can handle hills without problem with the system off, keep it off.
'05 Lotus Elise
'19 BMW M2C '22 Subaru WRX ex '15 Scion FR-S |
#4 |
Drive From Home
Drives: BRZ STI Performance
And giving it more throttle than needed will make you look like a total noob in traffic. Well either that or stalling it.
#5 |
The Gunshine State
Drives: '14 BRZ Limited
Great advice so far. Drive your car, learn your car, and you will never need to use hill-assist.
A little trick I used to use back when I was 16 was holding the e-brake up to prevent the car from rolling back and then released it once the clutch engaged.
![]() Current DD: M235i |
#6 |
Drives: 2013 FR-S 10 series [755]
E-brake is your best friend =]
#7 | |
#8 |
Drives: '05 Elise
The only two times I have ever used the ebrake was when coming out of very steep underground parking garage ramps.
'05 Lotus Elise
| The Following User Says Thank You to MarkR171 For This Useful Post: | FR-Sky (09-28-2016) |
#9 |
The Gunshine State
Well, I'm from FL, land of the hot and flat lol. We are not used to any kind of hills, generally.
| The Following User Says Thank You to 8RZ For This Useful Post: | FX86 (09-28-2016) |
#11 | ||
I had once got stuck in a very steep underground park exit with traffic....and the steep exit is very long too..... |
| The Following 2 Users Say Thank You to FR-Sky For This Useful Post: | SlammedSilly (09-28-2016), Tcoat (09-28-2016) |
#12 |
Wuss. Then it just becomes a sport!
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#13 | |
Drives: 2014 Scion FR-S
| The Following User Says Thank You to Jollibee86 For This Useful Post: | Tcoat (09-28-2016) |
| Anyone planning HAC (Hill Assist) retrofit? | Zardoman | Engine, Exhaust, Transmission | 28 | 06-06-2017 11:52 PM |
| Traction Control vs. Stabilization Control vs. Sport Question | MurderRider | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-07-2014 12:56 PM |
| Electric power steering assist to remote control | SeanBlader | BRZ First-Gen (2012+) — General Topics | 6 | 01-07-2014 10:16 AM |
| F/S: BNIB Homelink mirror, Digital HVAC control panel, Push Button Start | Opie | Interior Parts (Incl. Lighting) | 11 | 05-28-2013 11:53 PM |
| Car randomly doesn't start on slight hill | Craig | Issues | Warranty | Recalls / TSB | 7 | 02-01-2013 01:48 PM |
