View Poll Results: Do you have a problem starting your car on an incline?
Yes - with above a quarter tank of gas 2 11.76%
Yes - with less than a quarter tank of gas 0 0%
No - never had an issue starting 15 88.24%
Voters: 17. You may not vote on this poll
Old 09-24-2012, 08:23 PM   #1
Craig
Craig's Avatar
Drives: Asphalt FRS
Thumbs down Car randomly doesn't start on slight hill
I park my car on a driveway with a pretty slight incline. I park with the car facing the bottom of the hill, so obviously the gas in the tank will shift towards the front of the car. This has occurred twice now, both times with the gas below half but above a quarter tank. I've only ran the tank real low a few times usually to burn off gas which had ethanol in it, but thats besides the point.
When I have the problem, the car would attempt to turn over then rattle a bit. By the time the rattle occurs I stop turning the key, give it a second and try again. The second time, the car will stutter than turn over and drive without a problem.
I spend a lot of time parked on inclines, and it has only happened twice as I said, but considering how often I park in this way, I'm leery of excusing it especially considering the car's got ~2k miles on it now. I don't think this should ever be occurring, I could run my eclipse down to empty and park on an incline without any problems. Above a quarter of a tank is unacceptable in my opinion.
Anyone else have this problem? I tried the search but had no luck..
Craig is offline   Reply With Quote
Old 09-24-2012, 08:38 PM   #2
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Hmm yeah, that doesn't sound good. I often have my Eclipse near empty and parked on an incline without problems as well. I hope this doesn't become an issue with the FR-S... Of course, I could just make sure I always have more fuel in the tank. LOL
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 09-24-2012, 10:29 PM   #3
Craig
Craig's Avatar
Drives: Asphalt FRS
Its so infrequent and unpredictable I can't decide if its a problem or just some strange occurrence due to shitty gas..
Old 09-25-2012, 12:52 AM   #4
Bristecom
Bristecom's Avatar
Well try using some nicer Shell V-Power for a while. But it could be something else like the starter motor or fuel injectors or spark plugs having a problem.
Toyota + Subaru =
Old 09-25-2012, 03:27 AM   #5
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
**Could** be related to the CEL issue. My car threw a CEL for "Starting Malfunction", which was related to the whole Camshaft issue thing.
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 01-31-2013, 04:30 PM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
sorry to bring up an old post. since buying my BRZ in June, i have only had two instances where my car took longer to turn over than normal, both happened when parked on an incline (once with the motor facing the top of the incline, once with the motor facing the bottom).
Old 02-01-2013, 12:46 PM   #7
Lytheum
Drives: 2013 BRZ Premium 6MT
Has it been cold out? My car has taken several attempts to get it started after sitting in freezing weather.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 02-01-2013, 01:48 PM   #8
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
the incline could only be a coincidence ... sometimes my BRZ has issues starting, it will turn over 5-9 times before starting,... this has happened ~4 times in as many months... no incline...
microbionic is offline   Reply With Quote
Slight drop, world of difference. WheelDude.com FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 11-21-2014 05:05 PM
Wheel Directory: Konig Zero-In 17x7.0 +40mm mezdup Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-19-2014 08:17 PM
Slight grinding from the brakes... kndonlee Other Vehicles & General Automotive Discussions 7 09-15-2012 05:14 PM
Owner's manual slight confusion about engine break in period... davey90 AUSTRALIA 48 09-05-2012 09:51 PM
Castle Hill Performance T/C 86 mroczeK Engine, Exhaust, Transmission 91 08-22-2012 11:48 PM
