#57 | |
Lets say you have a scale, and you put a spring on it and tare it, and then stand on the spring. Now, you change that spring for a different rate spring, tare it again, and again, stand on the spring. Does the scale read a different weight for you? |
#58 | |
Drives: Nevermorange FRS
Force over time is what's at play. It's the same principle behind crumple zones, safer barriers and Hans devices. The force is reduced if spread over time. So if I clip a tall curb at the apex which applies 1500lbs of external force to my suspension, the force transferred to my shock tower is a function of how much of loading is spread over time. A 2000lb spring will spread that loading over less time vs a 500lb spring and thus transfer more force to the tower/body. The amount of external force that is transferred to the chassis is directly related to the amount of force that can be absorbed. Stiffer springs exactly means that more force is transferred to the chassis. edit: The best terminology is the word impact. A stiffer spring means that hitting a curb transfers more of the impact to the body.
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | Sleepless (09-05-2016) |
#59 | |
The Fail Boat
Drives: CWP S.B.
I don't think so? But If you get the Subaru flex bar + straw stiffener. (They are designed as a pair that works together instead of a giant bar) I'm sure if will have a positive effect over long term. Sent from my iPhone using Tapatalk |
#60 | |
#61 |
Affirmative. Same principle still applies. Force over time.
PRO86 | WTCC | STL
#62 |
Drives: '15 BRZ RA
Exactly. All these are well known properties discussed in forums a long time ago. Damian Harty (Prodrive) gave once some good feedback:
"the effectiveness of a strut brace is strongly connected to the stiffness of your suspension." |
#63 |
Drives: '15 BRZ RA
#64 | |
TRACKBREAD
![]() MAYBE a strut tower reinforcement plate like pictured above would have, but I still doubt it. These are used in E46s. (early 2000 BMW 3series) as their shock towers were on the thin side. They will stiffen them and thus help prevent a fatigue fracture. On this Porsche it looks like the vertical impact was just too much for the sheetmetal. That's not a fatigue failure. A brace does not transfer vertical forces well, only lateral forces, so it wouldn't have helped. -Josh |
#65 |
Off Topic
Whoopty doo. Does he have any experience racing this car beyond the theoretical? You said yourself that how effective these things are is very vehicle dependent, so why is it so hard to accept that on this specific chassis, they really add no value? Theory is great, math is great, but in the end I'll listen to the people who race this specific car and have tried everything in search of faster times. You seem to be dead set on the idea that all of these people, who have many many more track miles in this car than wonderboy engineer does, are wrong. Why? Because strut bars make a difference on other cars? Because they mathematically add some fraction of a percentage of stiffness? Show me practical unbiased results, not theory.
#66 | |
TRACKBREAD
-Josh |
#67 |
Off Topic
Mathematical differences can also be too small to provide any practical effect, which is what I think is happening here. Sure, any bracing will make the chassis stiffer to some extent. But to what extent? In this case, not very much. Not enough to be worth the money. On another car with different construction? Yes, absolutely.
#68 | |
Drives: 2016 FR-S
#69 | |
Drives: 2016 FR-S
#70 |
Off Topic
You sure it isn't a placebo effect? I'd want something I spent money on to make a difference too. So how much stiffer does a strut bar make the chassis on this car?
| Time Trial BMW M3 | endless_pain | Cars for Sale/Trade | 1 | 11-28-2014 03:02 PM |
| Strut Tower Bar VS Strut Tower Brace | norcalpb | BRZ First-Gen (2012+) — General Topics | 8 | 10-23-2014 10:31 PM |
| New Time Trial & Performance driving group | Saul_Good | Rocky Mountains / Great Plains | 3 | 06-25-2014 08:22 PM |
| FR-S sets new Time Trial track record at Roebling Road! | Arsenal Autosport | Tracking / Autocross / HPDE / Drifting | 28 | 08-18-2013 06:45 AM |
| FT86 cup time trial | sw20kosh | Northern California | 5 | 03-27-2013 03:27 PM |
