#43 | |
Drives: '15 BRZ RA
[ame="https://www.youtube.com/watch?v=-S6H7ZdzBfE"]Strut Bar - Explained - YouTube[/ame] |
#44 |
Off Topic
Rather listen to someone who's graduated high school already, thanks.
#45 |
I guess this car needed a strut tower brace. It's a Porsche GT4.
| The Following User Says Thank You to CSG Mike For This Useful Post: | FRS Justin (08-30-2016) |
#47 |
#48 | |
Drives: Nevermorange FRS
Joking aside. Stuff like this is why seem welding is desirable.
PRO86 | WTCC | STL
| The Following 2 Users Say Thank You to rice_classic For This Useful Post: | FRS Justin (08-31-2016), Jonsey (09-02-2016) |
#49 |
Drives: '15 BRZ RA
Porsche 911s don't have in front a double wishbone suspension. If someone changes the spring rates and go x2 or x3 stiffness, then he is fool enough to race without having extra bracing or other reinforcements. Personally, I' m not a Porsche fan and I don't care what someone should do in these cars. I KNOW what I should do in Subaru cars. And I am not saying I am smarter than others. I am just following the leaders. Mainly STi and a few others.
#50 | |
What it does change, is the spring constant, which means less compression. The load itself is unchanged. |
#51 |
Chin Chief Instructor
Drives: 2015 Ford F150 Aluminium Couch
Listen to CSG Mike. I've watched 2 other BRZ track cars owned by close friends with, literally, a few thousand miles on each car at Sebring alone, not to mention tracks all around the country. These cars are not babied. Neither car has had an issue that a strut tower bar would address. It's a waste of money. Period.
2015 Subaru BRZ
2008 NC Miata with 2.5 swap Building 1963 289 Cobra Le Mans Replica Cobra Replica Build Pics Chin Chief Instructor www.ChinTrackDays.com |
#52 |
I wasn't comparing, I was just stating what TRD is doing.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | FRS Justin (08-31-2016) |
#53 |
Drives: unlimited cheap build N/A track car
Changing the spring rates doesn't change the load experienced in the same area.
What it does change, is the spring constant, which means less compression. The load itself is unchanged. __________________ So are you saying stiffer springs will not increase the force exerted on the strut tower? |
#54 |
Drives: '23 BRZ Limited
What it changes is the speed of weight transfer.
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Racecomp Engineering (09-06-2016) |
#55 |
Drives: 2014 BRZ
And the force over time. So, the tower will see higher forces with a stiffer suspension over the same lap.
Serious hairsplitting and discussion for a really cheap device which does what it is supposed to do; reduce chassis flex at the struts and distribute loads between the two towers.
#56 |
Drives: 2023 BRZ
Yeah, I think I'll pass on getting one now.
But I do wonder, after the chassis has 150,000 hard miles on it, would the strut tower brace be more noticeable and effective? |
| Time Trial BMW M3 | endless_pain | Cars for Sale/Trade | 1 | 11-28-2014 03:02 PM |
| Strut Tower Bar VS Strut Tower Brace | norcalpb | BRZ First-Gen (2012+) — General Topics | 8 | 10-23-2014 10:31 PM |
| New Time Trial & Performance driving group | Saul_Good | Rocky Mountains / Great Plains | 3 | 06-25-2014 08:22 PM |
| FR-S sets new Time Trial track record at Roebling Road! | Arsenal Autosport | Tracking / Autocross / HPDE / Drifting | 28 | 08-18-2013 06:45 AM |
| FT86 cup time trial | sw20kosh | Northern California | 5 | 03-27-2013 03:27 PM |
