Drives: 2013 Red BRZ Limited
Air Filter Change
With the aftermarket intakes they all look like you have to practically remove them to get to the filter for replacement/cleaning. If not the air box at least the intake tube or am I missing something?
#2 |
Many of them you can just open up the intake box and slide a new filter in. Some of them you need to remove the bumper to get at the filter.
None of them provide a performance benefit, so only get one if you want a cool throaty growl.
#3 |
I am referring to the stock box replacement type.
#4 |
Drives: 2020 BRZ tS
From what I've read, even with the stock air box itself, it's easier to just take it out then trying to snap it back together under the hood.
#5 |
Drives: 13 frs red
It will snap in easy with the oem filter but sometimes requires a little persuation with aftermarket filter.
#6 |
I found replacing the OEM with K&N to be a PITA.
#7 |
Drives: 13 frs red
#8 |
Drives: brzzzz
what about this?
https://www.amazon.com/Green-Filter-...en+filter+2319 |
#9 |
Drives: 2016 Oceanic, "base" model
I just replaced my filter last night. Considering it was JUST an air filter, it was a RPITA. It required the intake box end of the intake tube to be removed so that the rear of the box could be opened up enough to slip the filter in and out. I miss the days of good ol' carburetors with the air cleaner just sitting on top of the engine held down by one or two wing nut(s).
#10 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
yall are a bunch of noobs.
| The Following 4 Users Say Thank You to Dr. BRZ For This Useful Post: |
#11 |
If you haven't been driving long enough to remember when changing your air filter was SIMPLE, some would say your the noob.
#12 | |
Is not fast.
Drives: 2014 Whiteout M/T
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
#13 |
[insert cool phrase here]
Drives: BRZ Premium
It's really not much of pain. Just 3 bolts 2 clamps a bit of wiggle and bam. It's out. With a beer in one hand of course.
Unless your a germaphobe or can't figure out what's a socket wrench, then yeah it's rocket science.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#14 |
Drives: 2005 Toyota Camry
Not my video:
[ame="https://www.youtube.com/watch?v=LTQjpVRuNVQ"]Subaru BRZ K&N Air Filter Install - YouTube[/ame] When I swapped mine out, it took me a total of maybe 5 minutes. No different than any other Japanese airbox-type OE filter from the past 20 years. -alex |
| Oil filter part number change, both #s deconstructed. | Calum | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 03-05-2023 01:02 PM |
| DIY Change in cabin air filter | VeganGirl | DIY (Do-It-Yourself) Guides | 11 | 06-06-2016 12:42 PM |
| Stupid Question: When to change OEM intake filter? | m.wood0213 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 02-17-2014 07:35 AM |
| Toyota Oil Filter Part # Change (sort of) | Moshpit37 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 01-02-2014 09:33 PM |
| How to just change the oil filter, not the oil? | GMT | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 24 | 12-10-2012 02:07 AM |
