Drives: 2013 Scion FR-S 6MT Asphalt
Please help with this silly question. Many of you have suggested that between oil changes, to change the oil filter often and just topping off the oil. I would like to start doing that. If I just loosen the filter and take it off, wouldn't the oil leak? When the engine is not operating will the oil filter be relatively empty since it is positioned high above the engine? I think I'm missing something here and would appreciate any advice you could give me.
Thank you.
- and yet, it moves! ... Galileo
Drives: '97 RSP JZZ30 GT-T
just pull it off. there wont be any oil in it.
Germans>Japanese>Italians>Americans. Unless its a Corvette. |
Drives: 2013 SWP BRZ
Seems like a waste of filter and money. But like posted above, you just take off the filter. No oil will be in it.
Registered you sir
Drives: 99 impreza coupe
Lefty loosey.
Registered you sir
Drives: Whiteout FR-S
Pulling it off right after driving and shutting off the engine I had quite a bit of oil coming out of it. I swapped filters another time after parking the entire night and not a single drop came out.
This is the knowledge I need. I didn't want to make a mess. I'm at 1000 mi and wanted to swap out the oil filter filter to get rid of any metal from the breaking in period. San Francisco Toyota won't perform the oil change until 7500 mi. It'll take me close to a year to get there so I was thinking about an oil filter change.
POINTLESS IMHO
#10 |
I'm not sure what that has to do with anything, but if an OEM Honeywell/Fram is fine in my Stage I Forester turbo for 7,500 miles a Tokyo Roki in a FR-S/BRZ is fine for 7,500 miles.
People really get hung up on old wives tales, myths, and oil information from the 80's, instead of taking the time to do a used oil analysis and find out for themselves. ![]() -Dennis |
#11 |
Registered you sir
Their oil lasts to the double digits; you just need to replace the filter midway through.
#12 |
Drives: none yet
I wouldn't worry about changing the filter between oil changes. Just get an oil change done earlier as the filter won't pick up all the metal particles and any trapped there stays there.
#13 | |
Drives: Nevermorange FRS
Possibly, but it costs $6 for a filter, takes 30 seconds to do it and it makes the driver the happy. The ontological argument says, "if he believes it to be real it is, to him." Let him believe, man... Let him believe.
However, call me a believer too but for other reasons, based in science and illustrated by Joe Gibbs (and also Amsoil but I don't have that bookmarked). I know he's talking about racing, sure, but it illustrates the point proven benefits of changing the filter often. http://www.drivenracingoil.com/dro/filters Quote:
#14 |
Drives: none yet
this is also for a nascar based engine that spins between 6000 and 9500 rpms for 2 hours straight, not a daily driver. I do understand the reason for this in a race when the engine is always in the upper rpm range and being pushed hard for a long time, just not in a street engine, but hey, if it floats your boat to do it, go ahead.
I'd probably be doing that if I had a 4-500hp engine, but then again I'd probably just change the oil at the same time due to blow-by getting in the oil and deteriorating it. my opinion, take it or leave it. |
| Oil filter part number change, both #s deconstructed. | Calum | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 03-05-2023 01:02 PM |
| Oil Filter | Hayashi | Hawaii | 2 | 02-20-2013 12:07 AM |
| WTB: TRD oil filter | 86_ZN6 | Engine, Exhaust, Bolt-Ons | 0 | 08-26-2012 12:50 AM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
| air filter | andy19804 | Engine, Exhaust, Transmission | 9 | 04-28-2012 03:35 PM |
