Old 08-27-2016, 12:43 PM   #1
X Factor
Drives: 2013 Red BRZ Limited
Air Filter Change
With the aftermarket intakes they all look like you have to practically remove them to get to the filter for replacement/cleaning. If not the air box at least the intake tube or am I missing something?
X Factor is offline   Reply With Quote
Old 08-27-2016, 12:53 PM   #2
phrosty
Many of them you can just open up the intake box and slide a new filter in. Some of them you need to remove the bumper to get at the filter.
None of them provide a performance benefit, so only get one if you want a cool throaty growl.
phrosty is offline   Reply With Quote
Old 08-27-2016, 03:01 PM   #3
X Factor
I am referring to the stock box replacement type.
Old 08-27-2016, 04:01 PM   #4
LancePower
Drives: 2020 BRZ tS
From what I've read, even with the stock air box itself, it's easier to just take it out then trying to snap it back together under the hood.
LancePower is offline   Reply With Quote
Old 08-27-2016, 04:26 PM   #5
Lantana frs
Drives: 13 frs red
It will snap in easy with the oem filter but sometimes requires a little persuation with aftermarket filter.
Lantana frs is offline   Reply With Quote
Old 08-31-2016, 11:54 AM   #6
X Factor
I found replacing the OEM with K&N to be a PITA.
Old 08-31-2016, 12:08 PM   #7
Lantana frs
Drives: 13 frs red
Same for me. Different lip configuration. Requires patience and a little persuasion.
Old 08-31-2016, 12:35 PM   #8
robotleader
Drives: brzzzz
what about this?
https://www.amazon.com/Green-Filter-...en+filter+2319
robotleader is offline   Reply With Quote
Old 08-31-2016, 12:41 PM   #9
MrDinkleman
Drives: 2016 Oceanic, "base" model
I just replaced my filter last night. Considering it was JUST an air filter, it was a RPITA. It required the intake box end of the intake tube to be removed so that the rear of the box could be opened up enough to slip the filter in and out. I miss the days of good ol' carburetors with the air cleaner just sitting on top of the engine held down by one or two wing nut(s).
MrDinkleman is offline   Reply With Quote
Old 08-31-2016, 12:57 PM   #10
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
yall are a bunch of noobs.
Dr. BRZ is offline   Reply With Quote
The Following 4 Users Say Thank You to Dr. BRZ For This Useful Post:
funwheeldrive (08-31-2016), G-awesome (09-06-2016), Mr.ac (08-31-2016), OkieSnuffBox (08-31-2016)
Old 08-31-2016, 04:59 PM   #11
X Factor
If you haven't been driving long enough to remember when changing your air filter was SIMPLE, some would say your the noob.
Old 08-31-2016, 06:12 PM   #12
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 08-31-2016, 08:52 PM   #13
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's really not much of pain. Just 3 bolts 2 clamps a bit of wiggle and bam. It's out. With a beer in one hand of course.
Unless your a germaphobe or can't figure out what's a socket wrench, then yeah it's rocket science.
Old 08-31-2016, 10:18 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Not my video:
[ame="https://www.youtube.com/watch?v=LTQjpVRuNVQ"]Subaru BRZ K&N Air Filter Install - YouTube[/ame]
When I swapped mine out, it took me a total of maybe 5 minutes.
No different than any other Japanese airbox-type OE filter from the past 20 years.
-alex
Oil filter part number change, both #s deconstructed. Calum Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 03-05-2023 01:02 PM
DIY Change in cabin air filter VeganGirl DIY (Do-It-Yourself) Guides 11 06-06-2016 12:42 PM
Stupid Question: When to change OEM intake filter? m.wood0213 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-17-2014 07:35 AM
Toyota Oil Filter Part # Change (sort of) Moshpit37 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 01-02-2014 09:33 PM
How to just change the oil filter, not the oil? GMT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 12-10-2012 02:07 AM
