Old 08-29-2016, 11:18 PM   #29
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Originally Posted by nikitopo View Post
There are numerous examples. If you don't like/trust Cusco, check the GT86 CS-V3 car we have here. It has a MASSIVE strut bar:
Looks like it has a large external reservoir mounting bracket that happens to connect the strut towers.
All joking aside, this is when you'd get a strut bar... a 100% complete, purpose built race car. It is literally the last thing you should think about adding to a car.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 08-29-2016, 11:35 PM   #30
surfwaxsmitty
Drives: '14 BRZ 6MT
Also, it is mounted along/around the entire strut mount
probably a range of changes that compliment this isolated reinforcement as well.
surfwaxsmitty is offline   Reply With Quote
Old 08-30-2016, 02:26 AM   #31
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Nope, it is one of the most basic mods because it works and it is very simple. Maybe it is not of much use on time trails, but for sure it helps on racing and even on the street (e.g. obstacle avoidance). It basically gives you a quicker steering. A difference of non using a strut bar with using one is measurable and it gives a difference on steering response of about 0.03sec. If you don't understand physics you can say that this is not a measurable difference, but on a car going 60km/h (37mph) it means that the car will start turning half meter (20 inches) earlier which is very measurable!
Old 08-30-2016, 02:49 AM   #32
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Additionally, you get more instant gripping during breaking instead of waiting the chassis to deform. I think this behaviour is explained better on this video:
[ame="https://www.youtube.com/watch?v=0r8xW03PVow"]STI flexible tower bar movie - YouTube[/ame]
Old 08-30-2016, 03:41 AM   #33
Ro_Ja
Drives: TOYOTA
One could counterpoint that the TRD Griffon, a purpose-built race car, does not have a strut brace.
Ro_Ja is offline   Reply With Quote
Old 08-30-2016, 04:20 AM   #34
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I can understand a lot of people are quick to dismiss the strut bar because of the fact that it doesn't help you be faster. But then there's another crowd that appreciates parts that enhances the driving feel and experience, which I'll dub as "feel" mods. IMO, a strut bar is a "feel" mod, so I'd put it in the same category as a master cylinder brace. I would even add aftermarket steering wheels and shift knobs as other "feel" mods as well. These are the type of items that will not make any significant difference in your lap times, but provides a positive difference in feel. And isn't the "feel" one of the main reasons we bought this car?
In short, whether a strut bar is worth it really depends on the person. But I can assure you, there is a positive difference (with the TRD bar at least; I haven't tried any others).
Old 08-30-2016, 06:16 AM   #35
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It has bigger V bars and reinforcements to the strut towers. You can either install a strut tower bar with the existing V bars, or change the V bars to bigger ones.
Old 08-30-2016, 07:43 AM   #36
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Do any of you road racers or time trial guys use a strut tower bar?
I don't know much but Maybe for cars that's rigid enough strut bar's effect is just very limited. Obvious it will help on a car that's just wide & has lots flex to it.
But on cars that very rigid front the beginning you just don't need one? Like NSX, Porsches, Ferrari, Lambos.. I don't recall they have a strut bar up front.
Old 08-30-2016, 09:39 AM   #37
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It depends the car. They might have a more complex suspension geometry in front, or the engine on the back . MacPherson struts with all the engine weight in front is not a good combination ...
Old 08-30-2016, 11:05 AM   #38
gramicci101
Off Topic
It depends the car.
It absolutely does depend on the car. And on this car, it makes very little to no difference. Which is why the people with hundreds of track hours in this specific car are saying not to waste your money on one.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
CSG Mike (08-30-2016), FRS Justin (08-30-2016)
Old 08-30-2016, 03:06 PM   #39
CSG Mike
CSG Mike's Avatar
Complex geometry doesn't change the basic fundamental mounting points. A Porsche is still a strut + lower control arm, and a Ferrari is still a double wishbone.
Old 08-30-2016, 03:21 PM   #40
Pat
Pat's Avatar
Drives: 2023 BRZ
Everyone, I appreciate your input on this. I feel like I have enough info now from experienced drivers to make an educated decision. Without this thread I didn't have confidence in my decision. Now I do.
Old 08-30-2016, 03:47 PM   #41
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Failure. The benefit of a strut brace is that it braces the strut.. Sounds obvious I know but if you are on track a lot and have high-grip tires those portions of the body which are held together mainly with glue and spot welds, can come apart. On the 86 I'm not sure how that plays out but I've seen it on lots of racecars.. Subframes tearing, strut tower coming apart at the spot welds etc etc.
So a big beefy bar (with no movable joints) can help steering feel but more important add bracing to a part of the chassis that could be under lots of back/forth stressing.
Fun lesson to remember is that failure is rarely eliminated, it's often simply transferred elsewhere.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
CSG Mike (08-30-2016), Toyarzee (08-30-2016)
Old 08-30-2016, 04:20 PM   #42
gramicci101
Off Topic
Speaking of transferring points of failure and spot welds coming apart, check this out.
http://www.ft86club.com/forums/showthread.php?t=105791
Because of that, if I were to buy a strut bar I would buy one that mounts all the way around the strut using all three bolts, not one that uses the existing strut brace points.
FRS Justin (08-30-2016), Jonsey (09-02-2016)
Time Trial BMW M3 endless_pain Cars for Sale/Trade 1 11-28-2014 03:02 PM
Strut Tower Bar VS Strut Tower Brace norcalpb BRZ First-Gen (2012+) — General Topics 8 10-23-2014 10:31 PM
New Time Trial & Performance driving group Saul_Good Rocky Mountains / Great Plains 3 06-25-2014 08:22 PM
FR-S sets new Time Trial track record at Roebling Road! Arsenal Autosport Tracking / Autocross / HPDE / Drifting 28 08-18-2013 06:45 AM
FT86 cup time trial sw20kosh Northern California 5 03-27-2013 03:27 PM
