Old 12-10-2014, 11:11 AM   #15
acj47
acj47's Avatar
OBDII Bluetooth scanner: ($19.99) [ame="http://www.amazon.com/ELM327-WIFI-OBD-Automotive-Diagnostics/dp/B00AQ99UQ0"]Amazon.com: Simvalley ELM327 WIFI OBD II Automotive Diagnostics Scanner for iPhone iPad iPod Touch: Automotive[/ame]
OBD Fusion app (iPhone) ($9.99) https://itunes.apple.com/us/app/obd-...650684932?mt=8
For less than $30 you can find out what the CEL is, and not have to do the "battery-disconnect-without-actually-finding-out-what-the-CEL-is" method.
acj47 is offline   Reply With Quote
Old 12-10-2014, 01:16 PM   #16
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I had a code throw...
Originally Posted by Thrustin View Post
Are there non-engine related codes that would cause the check engine light to come on?
It was something to do with the tranmission control system and it was only because of my messing around with power, disconnecting, reconnecting the battery. I used a regular code reader to delete the code and it hasn't come back.
Jaden
Jaden is offline   Reply With Quote
Old 08-27-2016, 01:19 AM   #17
brz2727
Drives: white brz
i connected my oft the turned off my car came back a half and hour later and had a check engine light out of no where any ideas as of why the check engine light came on its annoying the fuck out of me and has me scared to drive my car help
brz2727 is offline   Reply With Quote
Old 08-27-2016, 04:16 AM   #18
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Sometimes if you plug or unplug the OFT while the car is on, the check engine light will come on. Turn your car on and off a couple of times and it should clear.
eSOLOR is offline   Reply With Quote
Old 08-27-2016, 06:44 AM   #19
steve99
Drives: FT86
as above, you can induce codes if oft connection is lost while ignition on..
use your oft to read code
then google the code plus subaru
eg
google " U0150 subaru"
if its a communication loss code then dont worry
Old 08-27-2016, 07:52 AM   #20
brz2727
Drives: white brz
t
sweet it worked
Old 09-04-2016, 12:47 AM   #21
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
sweet it worked
yup..it happened to me too..
i never connect my OFT while ignition is on now lol
Old 01-05-2019, 04:48 PM   #22
OrangeGuitar
OrangeGuitar's Avatar
Drives: '17 BRZ Dark Grey Sport-tech 6MT
Bringing the thread back from the dead a couple years later. OFT says no ECU fault on a 2017 BRZ with catless UEL and stage 2+ tune. Code reader says P2270. O2 sensor signal stuck lean - bank 1 sensor 2.
Guessing this means the 91 premium gas I just filled up with from empty is not so premium. I usually run 93 but switch to 91 in winter. First time at that gas station.
I cleared the code and it did not come back right away. OFT shows LTFT between 0.00 and 0.78. STFT < 5 and AFR about 14.5 in normal driving.
OrangeGuitar is offline   Reply With Quote
Old 01-06-2019, 08:20 AM   #23
Kodename47
Kodename47's Avatar
Drives: UK GT86
That's the rear sensor.
.: Stealth 86 :.
Kodename 47 DJ:
OrangeGuitar (01-06-2019)
Old 01-06-2019, 12:14 PM   #24
OrangeGuitar
With a catless header, wouldn't this be expected? The sensor measures the efficiency of the cat which in this case is missing. Wouldn't the stage 2+ tune account for that? I guess I should check if the sensor came loose at least. New gas might have been a coincidence though. I've been running with this tune and header for the last half year.
Old 01-06-2019, 02:36 PM   #25
tomm.brz
Drives: brz 2017 hksv2
the code for catless is p0420, that code you have I think it s because you ( or who did the install) damaged the rear sensor or its wiring and the ecu is getting a stuck voltage from it, warning you it s not working
Old 01-26-2019, 05:01 PM   #26
OrangeGuitar
I reset it and it came back after a few days then cleared on it's own a day later. After a fresh tank of better gas, it has not returned after a couple of weeks. OFT did not read the code when the light was on.
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 10:28 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
Recognize these parts? Uoeno Cosmetic Modification (Interior/Exterior/Lighting) 32 07-22-2013 03:42 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
