Old 12-08-2014, 03:42 PM   #1
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
Exclamation Engine light on, but OFT does not recognize it
I have a '14 BRZ with Borla UEL. I'm running the stage II 93 octane tune.
All fluids seem fine, and it runs great. The header has been on for 1500 miles, or so with no issues. I did some research, and I expected the OFT to pull up an exhaust code, indicating that the header bolts may have loosened, but it's not recognizing anything at all.
Thoughts?
Thrustin is offline   Reply With Quote
Old 12-08-2014, 04:39 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
if you have a CEL but the OFT does not read it, it is because the code is non-engine related. Currently, the OFT only reads powertrain/engine related codes.
Old 12-08-2014, 04:42 PM   #3
jvincent
jvincent's Avatar
Does the OFT read the loose gas cap code?
That's my guess.
Old 12-08-2014, 04:47 PM   #4
Shiv@Openflash
Drives: 2013 FRS
That's my guess.
Yes, it should. That is an engine related code believe it or not
Old 12-08-2014, 04:57 PM   #5
Thrustin
That's my guess.
That was the first thing that I checked. It's on tight. OFT says, "No Fault Codes. Hurray!"
Old 12-08-2014, 04:58 PM   #6
Thrustin
Are there non-engine related codes that would cause the check engine light to come on?
Old 12-08-2014, 05:13 PM   #7
Shiv@Openflash
Drives: 2013 FRS
Yes, the most common ones are transmission control codes that occur in 6AT cars. For example, 6AT cars often get a CEL after each ECU flash caused by a TCU communication error. This is normal and clears itself after a few drive cycles.
Old 12-08-2014, 05:20 PM   #8
Thrustin
Mine is manual. Any other ideas?
Old 12-08-2014, 05:31 PM   #9
Shiv@Openflash
Drives: 2013 FRS
Yes, take it to the dealership and have them read the code
Old 12-08-2014, 05:36 PM   #10
steve99
could be many non engine related issues, you sometimes get a cel if your been drifting as the traction\ stability system gets upset.
does the cruise control still work ??
a cheap scantool will pull the code.
even though the oft wont read code it will clear all codes, but you should find out what it is before clearing it.
Old 12-08-2014, 05:56 PM   #11
wootwoot
Drives: FRS
Sure it's the engine light and not the tpms light? Just sayin...
wootwoot is offline   Reply With Quote
Old 12-08-2014, 06:09 PM   #12
Thrustin
lol, no
Cruise did not work. It works now though, as I disconnected/reconnected the battery. The engine light went away, and cruise works again. I guess I'll see if it comes back on.
Old 12-08-2014, 06:10 PM   #13
Thrustin
lol, I'm not a complete tard
Old 12-08-2014, 06:57 PM   #14
DarkestBuddha
Drives: BRZ limited GBS
get a cheap obd2 bluetooth reader and use torque or similar app to read/clear codes OFT cant.
i had the o2 sensor code (P0420) and for some reason the OFT didnt pick it up , but torque did.
DarkestBuddha is offline   Reply With Quote
The Following User Says Thank You to DarkestBuddha For This Useful Post:
Thrustin (12-08-2014)
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 10:28 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
Recognize these parts? Uoeno Cosmetic Modification (Interior/Exterior/Lighting) 32 07-22-2013 03:42 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
