#29 |
Keep ICE alive+manuals
Drives: 2015 Hot Lava 6 spd
Yes it more than likely will improve your 0-60, but keep in mind that it will cut your top speed down by gearing your car lower(numerically higher) because your engine will spin faster quicker and reach high rpm's faster and in most cases make your mpg's lower as well, like a double edge sword. In ny opinion the stock gearing (which i only drive manuals anyway) is geared low enough as is.
#30 |
Drives: MY11 Maxima 350st, MY15 BRZ
For what its worth, going to 4.556 in the A/T was pretty transformative. I don't feel the need to go higher as future mods will compliment the ratio ie Crawford power blocks, headers, custom tune etc..
Here's a useful thread on the Cusco 4.556 ratio I went for http://www.ft86club.com/forums/showthread.php?t=27647 I do also recall reading that if you go higher than 4.5 / 4.6 you may need to update the LSD also. Mine was a straight swap out though and has been amazing since.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
#31 |
Drives: 2013 black AT, OFT, 4.65
So, basically the low gear ratio, shorter gear, numeric higher gear is quicker(0 to 60 mph) but a lower top speed.
I am happy with my 4.67. Now Ponder this.. How could a Suzuki Samurai(65 hp, OBD 1)first gear ratio of 3.5 something, transfer case 4 to1 low and axle ratio 4:30 with lockers on 33s. Pull a 30 foot RV with a sand rail on a flat bed trailer stuck in sand. 300 feet across the Pismo dunes , and then 300 feet in to the dunes where a small block ford f150 could not. Gearing baby!!!!
Living the dream in a nightmare.
#32 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
If I say yes, will that make you think I understand?
#33 | |
Drives: Track preped NA FRS
#34 | |
#35 | |
#36 | |
| DIY - Transmission / Diff Fluid Change Reference Guide | F1point4 | DIY (Do-It-Yourself) Guides | 295 | 05-13-2023 02:34 AM |
| Trans and Diff fluid change feedback | Freedom | AFRICA | 0 | 08-07-2015 11:52 AM |
| Manual Trans./Diff. Fluid Change.?. | westmansweed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 07-15-2015 08:02 AM |
| Limited Slip diff oil Motul GEAR 300 LS 75W-90 | FRSToyota86 | Canada Classifieds | 12 | 08-22-2014 12:47 PM |
| Should I change my diff oil and tranny oil | Anthony7515 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 02-24-2014 11:30 AM |
