Old 08-18-2016, 11:15 PM   #29
HotlavaFRSGT86
Keep ICE alive+manuals
HotlavaFRSGT86's Avatar
Drives: 2015 Hot Lava 6 spd
Originally Posted by Riftur View Post
Ok so will the 4.88 gear change make my 0-60 faster in an AT car?
Yes it more than likely will improve your 0-60, but keep in mind that it will cut your top speed down by gearing your car lower(numerically higher) because your engine will spin faster quicker and reach high rpm's faster and in most cases make your mpg's lower as well, like a double edge sword. In ny opinion the stock gearing (which i only drive manuals anyway) is geared low enough as is.
HotlavaFRSGT86 is offline   Reply With Quote
Old 08-18-2016, 11:45 PM   #30
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
For what its worth, going to 4.556 in the A/T was pretty transformative. I don't feel the need to go higher as future mods will compliment the ratio ie Crawford power blocks, headers, custom tune etc..
Here's a useful thread on the Cusco 4.556 ratio I went for http://www.ft86club.com/forums/showthread.php?t=27647
I do also recall reading that if you go higher than 4.5 / 4.6 you may need to update the LSD also. Mine was a straight swap out though and has been amazing since.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 08-19-2016, 01:50 AM   #31
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
So, basically the low gear ratio, shorter gear, numeric higher gear is quicker(0 to 60 mph) but a lower top speed.
I am happy with my 4.67.
Now Ponder this.. How could a Suzuki Samurai(65 hp, OBD 1)first gear ratio of 3.5 something, transfer case 4 to1 low and axle ratio 4:30 with lockers on 33s. Pull a 30 foot RV with a sand rail on a flat bed trailer stuck in sand. 300 feet across the Pismo dunes , and then 300 feet in to the dunes where a small block ford f150 could not.
Gearing baby!!!!
Living the dream in a nightmare.
skye67 is offline   Reply With Quote
Old 08-19-2016, 01:19 PM   #32
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
A 4.88 fits just fine without messing with the LSD. Just ask @Lunatic. I also had a 4.88 in my car for a while, and it didn't require changing anything special, just the standard rebuild, pinion bearings, nut, seals and axle seals.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
The Following User Says Thank You to KoolBRZ For This Useful Post:
Mim (08-19-2016)
Old 08-19-2016, 02:10 PM   #33
Icecreamtruk
Drives: Track preped NA FRS
Not Lunatic but can confirm that there is no problem with the change aside from what you mentioned (which is normal stuff to change anyways). My car is hard tracked every weekend or so, in slicks, every still hold fine (except my coil pack A, that one likes to die but that has nothing to do with this topic).
Icecreamtruk is offline   Reply With Quote
Old 08-19-2016, 09:38 PM   #34
HotlavaFRSGT86
Glad to hear that your mods so far have made u happy, cause for what aftermarket parts cost for these cars is an entire paycheck for a lot of people, so for what their cost is they better put big smiles on our faces. 😂 I know i was skeptical about droppin $500 on the Vishnu tablet, but it has been awesome in my opinion and has made a big difference in performance enhancement.
Old 08-19-2016, 09:43 PM   #35
HotlavaFRSGT86
Gearing baby!!!!
Yeah Skye gearing is a huge thing for performance, i am a trucker and car/truck fanatic anyway, and how do u think our rigs are able to pull 80,000 lbs or more and even up steep hills? Gearing that is, first gear in a rig will have u redlining at about 3 mph depending on your setup. Of course our big diesel motors make stump pulling torque as well, but its the very low gearing is what makes them powerful.
Old 08-20-2016, 03:14 PM   #36
skye67
skye67's Avatar
The down side of that Samurai was turning 4000 rpm at 65 mph with a Magna flow and headers! It was my daily driver too!!
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 11:52 AM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 08:02 AM
Limited Slip diff oil Motul GEAR 300 LS 75W-90 FRSToyota86 Canada Classifieds 12 08-22-2014 12:47 PM
Should I change my diff oil and tranny oil Anthony7515 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 02-24-2014 11:30 AM
