Old 08-16-2016, 04:53 PM   #1
Riftur
Riftur's Avatar
Diff Gear Change
I know its been talked about a ton but i have been looking around the threads and cant find it. Whats the diff gear I want to change my 13 FRS AT to for more low end torque? I think it was 4.88 but i forget. Sorry to ask this question when i know its been talked about plenty.
Thanks,
Riftur is offline   Reply With Quote
Old 08-16-2016, 05:15 PM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Cusco makes 4.55 final drive. Autofactory makes 4.875 final drive. Just google "final drive ft86club".
Old 08-16-2016, 09:26 PM   #3
humfrz
Thanks,
I reckon that depends on where you want the car to go (do).
After you find out what ratios are out there, you may wish to consult with one of the on-line calculators to figure which one fits your needs best.
http://www.catherineandken.co.uk/sti/tyres.html
humfrz
Old 08-16-2016, 10:55 PM   #4
Reamer
Drives: 2015 FRS
I may (probably) be completely wrong about this, but changing the diff won't make the car have any more low-end torque than it already does. However, it'll be the illusion of low-end torque since the shorter gears makes it easier (faster) for the car to get in the higher RPM range where the car's power actually lies. I own a AT and I'm planning on going with 4.88 as well.
Reamer is offline   Reply With Quote
Old 08-16-2016, 11:12 PM   #5
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
You are right about being completely wrong haha. Think of it as changing gears on a bicycle to the largest ring in the back; It isn't just the illusion of torque the larger gear actually produces more torque. Just like the on a bicycle the gear will affect how fast the cyclist will need to peddle to achieve a given speed, and the speeds achievable in any given gear.
In the car that means each gear will be reduced by 5-10 mph so instead of hitting 60 in second gear, you're now hitting 50 (don't know the exact numbers). The increase in torque has nothing to do with "getting into the higher rpm" and everything to do with the physics of gears.
headlikeahole is offline   Reply With Quote
Old 08-16-2016, 11:24 PM   #6
KoolBRZ
KoolBRZ's Avatar
Get the 4.88 and a 2nd rear carrier
It won't give your car any more torque or horsepower. That said, it will give you more horsepower per revolution of tire. More important, it will reduce the gap between gears, making it easier to stay in the power, and out of the torque dip. Most people have no idea how abysmally geared the AT's really are. I mean it double-clutches 2nd gear because the stretch between 1st and 2nd is so wide. An AT would have to upgrade to a mythical 5.40 FD to even come close to equaling the MT gears.
I'm getting a 2nd rear carrier rebuilt right now with a 4.88 gearset. I'm currently running a 4.30 and just got 42.1 mpg @ 55 mph on my way down to Sacramento. I'll use the 4.88 for track days and city driving, and the 4.30 for road trips.
If I say yes, will that make you think I understand?
Old 08-16-2016, 11:41 PM   #7
KoolBRZ
KoolBRZ's Avatar
People get all worked up over this because it feels like more power, and it feels like a close-ratio transmission. It doesn't give the motor any more power, but it gives it more leverage, since the motor gets to spin more revs per rev of each tire. The transmission gears don't get any closer together, but the gap between shifts becomes closer, since the motor is spinning faster in every gear.
It's an argument between what you feel, and what is measurable at the crank.
A FD change can actually make a car slower on the track, since it might not stay in the ideal gear through the corners, and the top gear is still too tall for the straightaways.
Old 08-17-2016, 12:18 AM   #8
Icecreamtruk
Drives: Track preped NA FRS
As someone who runs a 4.88 FD at the track. I can confirm, I think it is slower in some tracks (but faster in others). It really depends on the situation (do I need 6th or not for the straight, do I need to shift mid turn, etc...)
Old 08-17-2016, 07:27 AM   #9
Riftur
Riftur's Avatar
I do not track my car. I just need a bit faster 0-60 for DD. I was told this is the best way to do it with 4.88 gears. Is this not true?
Old 08-17-2016, 08:12 AM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Best bang for buck mod on this car is E85 tune with header.
Old 08-17-2016, 08:15 AM   #11
Reamer
Drives: 2015 FRS
Do you have AT or MT?
What about the diff change if you already have those?
Old 08-17-2016, 09:22 AM   #12
Riftur
Riftur's Avatar
I have an AT and the gear change would be a nice undercover upgrade that wont effect my warranty.
there is not an e85 station close to my house and this is for DD. If i was tracking I would go with e85.
Old 08-17-2016, 10:18 AM   #13
Icecreamtruk
I have a MT. It might work better for AT, since that will turn out similar to a 4.5 on a MT and I think the sweetspot is somewhere between 4.3 and 4.5 for a manual (2017 MT models have 4.3 FD, maybe they are onto something?)
Old 08-17-2016, 11:06 AM   #14
Riftur
Riftur's Avatar
Ok so will the 4.88 gear change make my 0-60 faster in an AT car?
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 11:52 AM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 08:02 AM
Limited Slip diff oil Motul GEAR 300 LS 75W-90 FRSToyota86 Canada Classifieds 12 08-22-2014 12:47 PM
Should I change my diff oil and tranny oil Anthony7515 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 02-24-2014 11:30 AM
