Old 07-22-2016, 05:48 PM   #323
_gt86_user
Inactive
Drives: .
Originally Posted by lizbrayan View Post
I just tuned my car to the oft stage two uel tune using ecuflash and tactrix, what would i change in the map to achive this?
Sent from my SGH-T999N using Tapatalk
Base Timing B to 0 to -15 anywhere in between will produce sounds as well. need to feather the throttle blah blah its all been said before.
_gt86_user is offline   Reply With Quote
Old 07-22-2016, 05:51 PM   #324
lizbrayan
Drives: '15 Scion Frs Steel
Thats it? which colom do i lower the numbers in? And it works just the same with an automatoc right?
lizbrayan is offline   Reply With Quote
Old 07-22-2016, 06:33 PM   #325
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Seriously? Did you not read the original post? Learn to use romraider.
Old 07-22-2016, 06:53 PM   #326
lizbrayan
Wasnt sure if ot was different with stage 2 or not just wanted to make sure bud
Old 07-23-2016, 03:23 PM   #327
lizbrayan
So i went to flash this new map with the backfire and ecuflash said there was an error it was J2534 error (no devices available). Any help ?
Old 07-23-2016, 03:39 PM   #328
FLESH KILLA
Mr Cool Guy
FLESH KILLA's Avatar
Drives: 2013 Scion FR-S (Raven)
I would make sure you have a good obdii connection and turn everything off. Was trying to flash my ECU a few weeks ago and got an error. Reseated the OFT cable and made sure to turn off all electronic like the dome light, ac recycle (amber LED) and radar detector. I haven't had any issues flashing the ecu since. Just my suggestion...
Sent from my Nexus 6P using Tapatalk
- RAVEN 86 -
FLESH KILLA is offline   Reply With Quote
Old 07-23-2016, 04:17 PM   #329
steve99
Drives: FT86
That sounds like an error between Ecuflash and the Tactrix hardware (its J2534), not an error talking to vehicle ECU
Old 07-23-2016, 04:22 PM   #330
lizbrayan
Thats odd, i flashed the car yesterday no probme, how do i fix it?
Old 07-23-2016, 05:38 PM   #331
steve99
Drives: FT86
could be many things.
usb cable or port problems
tactrix hardware failed
some other software using port
try re-installing ecuflash and driver software
if ecuflash can see tactrix adapter the read and write icons will be red and blue, if they are grey ecuflash cannot see tactrix adapter hardware
Old 07-23-2016, 06:38 PM   #332
renfield90
The Stig's German cousin
Could be an intermittent connection. You plug it in one day, it flashes fine, you plug it in the next day but you didn't plug it in quite exactly the way you did the first day and you get communication errors.
To get a J2534 "no devices available" error, I would expect the entire software stack from computer all the way to OBDII port to be working fine, but when it tries to talk on the bus, it doesn't receive any discernable reply.
Our OBDII port sucks. I gently bent the pins on my Tactrix towards the center a bit and it's better, but it's still typically a few tries to get a flash to go through. It's not just the Tactrix though, my Bluetooth OBD dongle doesn't make a good connection sometimes.
Old 07-23-2016, 07:22 PM   #333
lizbrayan
Alright so i went in tried again and still nothing. Only difference is that there is no error code.
Old 07-23-2016, 09:22 PM   #334
renfield90
So you've tried three times and you have a different result each time, but you've made no changes to the software you have? You have a hardware issue. Probably involved with the connector. Bend the Tactrix pins inward 1-2mm and try again.
Old 07-23-2016, 09:26 PM   #335
steve99
Drives: FT86
what colour are the ecuflash icons on screen for read and write ?
if they are red and blue your talking to tactrix adapter if they are grey your not getting connection to tactrix or its not being recognised by ecuflash.
are their and led lit up on tactrix adapter ?
If the icons are rad and blue then its talking to tactrix
next look on the ecuflash log screen how far is it getting down the list below
[18:26:55.826] using metadata XML ID read_subarush72531brz from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_subarush72531brz.xml
[18:26:55.841] J2534 API Version: 04.04
[18:26:55.841] J2534 DLL Version: 1.01.4035 Dec 16 2013 23:12:40
[18:26:55.841] Device Firmware Version: 1.14.4010
[18:26:55.841] Device Serial Number: TAAVR*Nx
[18:27:03.382] reading vehicle info...
[18:27:03.414] CALID : ZA1JA01D
[18:27:03.429] CVN : ED0690B9
[18:27:03.429] VIN : JF1ZNAA12D272####
[18:27:03.429] starting programming session...
[18:27:03.429] turning off DTCs...
[18:27:03.773] turning off unnecessary communications...
[18:27:03.882] unlocking ECU...
[18:27:03.882] Requesting Seed...
[18:27:03.882] interface close
[18:27:03.898] interface close
Old 07-23-2016, 09:54 PM   #336
lizbrayan
Yeah the icons are lit red and blue and the log is all exactly like that. Imma double check the logs after i charge my laptop. Imma also try pushing the pins in a little its just a little frustrating that it worked two days ago and now nothing.
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
