Old 03-09-2014, 11:28 PM   #1
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
rom tuning for pops and backfires
I want my car to backfire and pop more. I'm on oft stg2 with Jdl uel and Tomei type 80. it occasionally pops when engine braking to a stop and blipping when putting in neutral, and also up shifting, but i want it to happen more often. what should I change in my rom to get this? from what I understand, pops are from extra fuel, oxygen in the exhaust, and retarded ignition, but how can I safely tune for it while keeping max power and efficiency? don't comment on this being ricerish or bad for the environment/neighborhood, it's ****ing awesome
andrew5826 is offline   Reply With Quote
The Following 2 Users Say Thank You to andrew5826 For This Useful Post:
Flat_4_Life (04-23-2015), Gilwith1l (03-29-2014)
Old 03-10-2014, 11:45 AM   #2
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
ive been surfing the tablet and learning the tuning with it since the day it came out trying to do this. nobody will help us on any forum they jus ignore it..its closed loop area you can dump fuel but i havnt found how to control timing. it always goes to 32-34deg
IG-Joey_Soul
Old 03-10-2014, 12:02 PM   #3
Malt
Drives: 2015 WRX
Not sure if you are serious or not....
Malt is offline   Reply With Quote
The Following 2 Users Say Thank You to Malt For This Useful Post:
CaptainSlow (03-17-2014), SirBrass (03-10-2014)
Old 03-10-2014, 12:08 PM   #4
steve99
Try the waranttee return bin at the dealer for some Direct Injectors with crook DI seals = pops
Remove port injectors , run a 1/8" drill bit through 'em should make it run rich = backfires
Malt (03-10-2014)
Old 03-10-2014, 12:14 PM   #5
Malt
Drives: 2015 WRX
Or you could remove the primary O2 sensor and pipe the fuel pump return line into that port.
The Following 3 Users Say Thank You to Malt For This Useful Post:
#maverick# (01-10-2015), SloS14 (03-10-2014), steve99 (03-10-2014)
Old 03-10-2014, 12:26 PM   #6
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
it's tough to find good help on this forum, everyone seems to think they're funny.. would changing the decel fueling be a step In the right direction?
Sent from my SGH-I337M using Tapatalk
Old 03-10-2014, 12:27 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
Perhaps retard the ignition in the decel columns?
What sort of injector overrun settings can you alter?
2013 FRS
Vortech V3 11psi
Old 03-10-2014, 12:33 PM   #8
mad_sb
Drives: 2013 Asphalt FR-S
A front pipe with a highflow metal core cat will help. As for tuning, your wanting to add fuel in an area where the ecu has cut off the injectors (decel / lift throttle) so your going to have a hard time. You can target richer afr under load and mess around with the decel fueling tables a bit.
Your not going to find a lot of people that tune for this on purpose so the knowledge is probably just not there. But there is nothing stopping you from figuring it out.
Log, adjust, test, repeat
The Following User Says Thank You to mad_sb For This Useful Post:
aagun (11-30-2016)
Old 03-10-2014, 01:15 PM   #9
Grip Ronin
The Mechanic
Grip Ronin's Avatar
you could but it wont give you the effect you want without pulling timing
IG-Joey_Soul
Old 03-10-2014, 01:18 PM   #10
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We do this with EcuTek using custom maps.
[ame="http://www.youtube.com/watch?v=xFo9NOKmcrY"]BRZ Supercharged w/UEL Night Run - YouTube[/ame]
It can be done.
Xero-Limit is offline   Reply With Quote
The Following 8 Users Say Thank You to Xero-Limit For This Useful Post:
Ammonia (03-20-2014), Bach415 (03-12-2014), Darryljr11 (08-02-2014), DJCarbine (03-10-2014), GT86_PRAGUE (08-19-2015), IAmNotTheDriftKing (03-18-2014), Migero86 (03-10-2014), racecaresuaceb (04-07-2014)
Old 03-10-2014, 07:41 PM   #11
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
It can be done.
reveal the secret!
Old 03-10-2014, 08:44 PM   #12
Grip Ronin
The Mechanic
Grip Ronin's Avatar
It can be done.
it sounds good but can it be done without F.I? ive seen the turbo frs's do it
IG-Joey_Soul
Old 03-10-2014, 08:52 PM   #13
Xero-Limit
Xero-Limit's Avatar
Yup, no FI needed. Just RaceROM.
Old 03-10-2014, 09:08 PM   #14
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I'm quite sure it's possible to do by just remapping the active ignition table and by playing around with the duration for throttle enrichment.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
mad_sb (03-11-2014)
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 02:23 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
