Old 09-30-2013, 04:22 PM   #1
jamesm
First romraider defs are up
the first romraider defs have been posted: http://www.romraider.com/forum/viewt...hp?f=34&t=9999
also, look for the ecuflash beta supporting flashing the 86 ecu within a week or so. exciting times!
Old 09-30-2013, 04:24 PM   #2
ML
ML's Avatar
Drives: 13 White MT FR-S
Awesome! Will there be a library of roms/flashes available? How does this work with other platforms regarding finding roms others have made?
Old 09-30-2013, 04:32 PM   #3
jamesm
the community will step in for that. i've been working on an app that takes a list of modifications and spits out relevance-ranked tunes (uploaded by other users) based on their configuration, but it's not complete yet. been real busy with work lately. hopefully i'll wrap it up soon or we'll get a subforum on here, something like that.
Old 10-01-2013, 12:13 AM   #4
JuniorAWD
Drives: GTR 9.0@170_XT 10.8@130_GC 8.3@165
Good stuff
JuniorAWD is offline   Reply With Quote
Old 10-01-2013, 10:03 AM   #5
xwd
Does RomRaider support the OpenFlash formatted files or vice versa? Would be nice to be able to use RR for people familiar with it for tuning and then use the OF device for actual flashing so you aren't carrying around a laptop all the time. I know BRZEdit quickly added support for the OF file format.
Old 10-01-2013, 11:25 AM   #6
jamesm
they're just the raw, unencrypted bin so i would assume it will work fine. the one area that is an issue is where tables that don't exist in a stock rom (and thus aren't defined in the romraider defs) like flat foot shift come into play.
i was able to open the stock (ecuflash-pulled) rom in tunerpro using the openflash defs but it froze when i tried to open a map that didn't exist. i imagine the something similar is true for the opposite.
Old 10-01-2013, 11:54 AM   #7
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
As far as I can tell, the OpenFlash and RomRaider defs are based on the same base rom/calibration id and pretty much work interchangeably. There are a few naming differences in the maps. The only real difference is the custom FFS/LC stuff and the missing bootloader at the beginning of the OpenFlash rom.
FrX is offline   Reply With Quote
Old 10-01-2013, 03:58 PM   #8
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Will definitely work on the OpenFlash roms, since it's the raw bin, and both platforms merely work like glorified hex readers (with OF using the XDF format, and RR XML). I assume it will be much the same with Brzedit roms.
Closed platforms, like Ecutek, will likely not work.
Td-d is offline   Reply With Quote
Old 10-06-2013, 01:51 PM   #9
jamesm
I've forked your repo and added a couple more useful definitions, Primary Open Loop Fueling and Transient Ignition Retard to the Alpha - BRZ section. if you like i can put in a PR for you to review/test/merge.
https://github.com/jmartin2683/SubaruDefs/tree/Alpha
Old 10-06-2013, 03:31 PM   #10
FrX
Primary open loop fueling was already defined in the def as "Primary Open Loop Fueling Cruise". It looks like it didn't have an associated description in the 32bitbase, however, so it may not have shown up. The transient tables were missing as far as I see, though.
Old 10-06-2013, 03:37 PM   #11
jamesm
Weird I didn't see that. Oh well, it's there in any case lol. Transient map wasn't defined, though a couple related tables were (can't remember which ones without looking).
Old 10-06-2013, 04:53 PM   #12
Td-d
Thanks for that - both were defined, but looks like I missed defining the transient ignition table in the base, and the fueling table dropped off the last time I ran the template.
Code:
ROM:000CECF8 Table_Transient_Ignition_Retard:.data.w 7 ; DATA XREF: sub_6F170+6Eo
ROM:000CECF8                                         ; ROM:off_6F340o
ROM:000CECFA                 .data.w h'18
ROM:000CECFC                 .data.l Transient_Ignition_Retard_X_Axis
ROM:000CED00                 .data.l Transient_Ignition_Retard_Y_Axis
ROM:000CED04                 .data.l Transient_Ignition_Retard ; = -9.961
ROM:000CED08                 .data.l h'4000000
ROM:000CED0C                 .float 0.3515625
ROM:000CED10                 .float -30.0
Check out the latest revision on Github - I've incorporated the definition for all the new DTCs in the base , so they are all accessible now.
Old 10-06-2013, 05:03 PM   #13
jamesm
Code:
sweet, thanks!
Old 10-06-2013, 05:05 PM   #14
Td-d
Ok - I've fixed up the fueling table and inserted the transient ignition table definition - rather force fast forward your fork to my latest, since I put the definition both in the 32bitbase and the ZA1JA00C.xml (so it can be used in future for other territory variants of the rom).
