Old 07-11-2016, 01:21 PM   #1
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Warm area inside cabin when driving car hard + hot weather question
So lately, its been kind of hot and humid here in north jersey/nyc area. Last friday ,after i did the oil change, i noticed/felt the cabin warmer than usual (mostly by the pedals or around that area).
Then yesterday, i went for a mountain drive and noticed the same thing after driving the car for about 200 miles in total..
I always drive this car hard but never fully red line on every gear or burn clutch, etc... (also I do not use the AC most of the times.)
I checked my oil and coolant level and they all seem ok. No burning smells or hot temp on engine.
Could it be just the heat from the engine bay? Strange that i only started to noticed this recently..
Let me know if anybody has experience this !
Jfheisenberg is offline   Reply With Quote
Old 07-11-2016, 03:40 PM   #2
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
There is always air flowing in the HVAC system. What you have is your vents pointed to the foot wells and the warm ambient air from the engine bay pumping in. I point mine o the windshield when I'm windows down as this keeps the warm space away from me. Probably only noticed it because of where your vents are set to this time with the warm weather.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Old 07-11-2016, 04:16 PM   #3
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Try to set the system to cold air directed away from you BEFORE turning the system off.
It stays how you last left it when you turn it off and hot air will blow out even with it off.
justatroll is offline   Reply With Quote
Old 07-11-2016, 04:23 PM   #4
gramicci101
Off Topic
If your mountain drive was a hard drive, then the AC compressor clutch disconnects based on throttle position, to remove parasitic loss and free up power. So if you're flooring it between corners, all of a sudden it'll be blowing warm/hot air at you when you put your foot down, because the compressor is no longer compressing.
In a hot environment when you first start the car up, the idle RPM will not spin the compressor enough to reach full capability. So the air will be room temperature to kind of cool. It doesn't really cool down until you can get the RPM up (ex. driving away).
The Following User Says Thank You to gramicci101 For This Useful Post:
FRSBRZGT86FAN (07-12-2016)
Old 07-11-2016, 04:32 PM   #5
Jfheisenberg
Thats very possible, however i only noticed most of this warn area to be by the pedals (clutch, brake, gas)
Im going to try to close the vents and see if that makes a difference.
Interesting thanks !!
Old 07-12-2016, 11:53 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This is important and alot of people don't realize this, in alot of "pull" or acceleration videos of exhausts and stuff you can even hear the compressor clicking on and off. Alot of people have a tendency to say the A/C is crap on a super hot day, but go hard throttle before it has a chance to work on the heat load.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Jfheisenberg (07-13-2016)
Rolling nut sound towards rear area of cabin Jajanken86 Issues | Warranty | Recalls / TSB 4 06-18-2016 12:48 AM
Do you warm up the car every morning b4 driving? qqzj BRZ First-Gen (2012+) — General Topics 56 04-24-2014 03:18 PM
How long do you warm up car before driving? djmm Scion FR-S / Toyota 86 GT86 General Forum 62 04-13-2014 02:34 AM
Engine cutting power after hard cornering... Video inside CSG Mike Engine, Exhaust, Transmission 4 08-21-2012 08:06 AM
Warm vs cool Weather performance EsoBOFH Scion FR-S / Toyota 86 GT86 General Forum 22 07-10-2012 11:45 AM
